rear window #759633 10/21/06 01:33 AM
1990 4Runner, The rear window will not go up. Its not the motor what else should I be looking at? Thanks
Re: rear window #759634 10/21/06 01:51 AM
Dis you try the key in the back door. Also there is the window lock button next to the up and down button, mine has gotten stuck sveral times. If not one of these pull the switch out and test it,if you have a test light you can find the wires that are for up and down only and jump them. it takes alittle time but is pretty easy.
Re: rear window #759635 10/23/06 07:23 PM
Tommytuttle Offline
I had the same problem with the switch. Kept thinking the door was not latched.
Tom P
2000 4runner 5spd SR5 (pretty much stock) Bridgstone REVO(275/70r16)
Re: rear window #759636 10/24/06 06:53 AM
4Crawler Offline
PHP: 7.4.33 Page Time: 0.013s Queries: 14 (0.010s) Memory: 0.5931 MB (Peak: 0.6504 MB) Data Comp: Off Server Time: 2026-11-02 19:25:59 UTC
