gas gauge, oil temp gauge stoped workin. #759810 10/22/06 06:56 AM
P
philly Offline OP
i was offroading today on cape cod. where i find a poor jeep xj lifted wiht 33s stuck in the sand. after pulling him out i mess around a little bit and go home.
Truck. 91 pickup... 3.slo.. automatic.. lifted blah blah blah.
so i'm drivin home and then i notice my oil temp is gone and my gas is totally empty... that cant be right. i pulled over and check every fuse. but they all looked good.. then as i was leaving i noticed that when i apply the break and try to shift from park to drive it dosent unlock the lock. and it took a few times to get the engine running cuz the battery light came up.. i am going to try a new battery in the morning and check all connections evverywhere.. any tips?
Re: gas gauge, oil temp gauge stoped workin. [Re: philly] #759811 10/22/06 07:20 PM
stock87 Offline
Check the ground point in the drivers side kick panel. Should be two white wires with black stripes going to a loop that's bolted to the metal. If that has come loose, it could cause what you're describing, since that's the main ground point for the cluster.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: gas gauge, oil temp gauge stoped workin. [Re: stock87] #759812 10/22/06 08:12 PM
P
philly Offline OP
i've been checking stuff all morning and cant figure this out. what tells how much gas i have and what temp my oil is??
Re: gas gauge, oil temp gauge stoped workin. [Re: philly] #759813 10/23/06 08:17 PM
P
philly Offline OP
well today i noticed none of the air/heat controls work.. soo iduno i have an extra thermostat im gona try.. gona get some prices on a fuel gauge sending unit and a oil pressure sender
and hope that cures it!.. what about a relay somewhere??
Re: gas gauge, oil temp gauge stoped workin. [Re: philly] #759814 10/23/06 08:46 PM
stock87 Offline
For starters, it's an oil pressure gauge, not temp.
Secondly, all those gauges share a common ground point, so it's about a one in one bazillion chance that all the senders failed all at once.
Take the kick panel off by the clutch pedal (below the fuse box) and check the ground point there. It should be securely attached.
If that doesn't solve it, you'll probably want to pull the cluster and check the wiring going into it.
Re: gas gauge, oil temp gauge stoped workin. [Re: philly] #759815 10/23/06 08:47 PM
BrokeAsAJoke Offline
The gauges are basically ohm meters and the sending units are variable resistors. You can test the resistance of the senders. If they are in range, then there is no reason to replace them and the problem is in the gauge cluster. To test the gauges, you can tap the leads to the senders together and see if the gauges jump. (I've never done this, so someone correct me if this would damage the gauges, but I don't think it would)
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
Re: gas gauge, oil temp gauge stoped workin. [Re: BrokeAsAJoke] #759816 10/23/06 08:50 PM
DRTDEVL Offline
THIS TEST WILL PERMANENTLY DAMAGE YOUR OIL PRESSURE GAUGE!!!!!
Check the ground, as previously posted.
Re: gas gauge, oil temp gauge stoped workin. [Re: DRTDEVL] #759817 10/23/06 10:01 PM
P
philly Offline OP
wow what a retard i am.. i checked fuses again today by pulling them each out.. and i dicsovered a burned one.. yesterday with a test light i did not find this. the gaugues fuse was burned out.. replece. and i got my gauges back. thanks for the responces guys
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6235 MB (Peak: 0.7230 MB) Data Comp: Off Server Time: 2026-07-14 08:18:23 UTC
