31x10x15 on a stock 15x6?? #760316 10/24/06 03:03 PM
Robb Offline OP
Is this setup possible? Found a good deal I would hate to pass up.
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: 31x10x15 on a stock 15x6?? [Re: Robb] #760317 10/24/06 03:36 PM
sparkem Offline
Search and Yes it will fit.
Re: 31x10x15 on a stock 15x6?? [Re: sparkem] #760318 10/24/06 04:31 PM
Y
yankee7809 Offline
Had 'em on my '95 LS for 150,000 miles.It works great
1995 Montero LS, KYBs, Michelin 31s. 2009 Kia Borrego EX. (Wife's wheels.)
Re: 31x10x15 on a stock 15x6?? [Re: Robb] #760319 10/24/06 04:58 PM
Look at the pictures on my Homepage. My Montero has that setup right now, however I am going to be getting 33/12.5/15 but on a 10" rim in the future.
Re: 31x10x15 on a stock 15x6?? #760320 10/24/06 08:34 PM
DRaider90 Offline
That is the general guide. But 31's are common on the 15x6 rim. Some have even went to 32's, but its pushing it. 33's and up defiently need a wider rim. So you should be fine. <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
Re: 31x10x15 on a stock 15x6?? [Re: DRaider90] #760321 10/24/06 08:38 PM
powerRam50 Offline
i had 31's on my stack rims.the only problem is some tire shops wont mount thst wide of a tire on that norrow a rim but i found one that would.i never had a problem.
Re: 31x10x15 on a stock 15x6?? [Re: powerRam50] #760322 10/24/06 09:02 PM
Robb Offline OP
Thanks for the great info!
-Robb
1992 Montero (pics)
Re: 31x10x15 on a stock 15x6?? [Re: Robb] #760323 10/25/06 12:06 AM
sparkem Offline
I ran 32x11.5 on my stock 6in for a couple years, no problems.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6205 MB (Peak: 0.6979 MB) Data Comp: Off Server Time: 2026-06-23 21:17:34 UTC
