Idle/Power Problem. #760324 10/24/06 03:26 PM
sjs Offline OP
I have a problem with a rough and low idle when my Sporty is in gear. It is a little rough when it isn't but high enuf, but it seems like it has a miss. Also, when the car is cold it lacks power off the line but is okay once it gets going. When warmed up the power problem goes away. I cleaned all the connectors and the IAC and reattached them. Coils, plugs and wires replaced. No CEL.
BTW, I recently did the timing belt and water pump. The reason all this work was done was because my Sporty overheated badly. I changed the radiator and the heater core. Thanks to all on this forum for all the tips on how to do all the work I did.
Re: Idle/Power Problem. [Re: sjs] #760325 10/24/06 03:53 PM
fokion Offline
How sure are you that overheating didnt cause any side-effect problems??
Re: Idle/Power Problem. [Re: fokion] #760326 10/24/06 04:40 PM
sjs Offline OP
I'm not sure. Could overheating cause these problems?
Re: Idle/Power Problem. [Re: sjs] #760327 10/24/06 07:07 PM
A
Airdale73013 Offline
Check and clean the connectors on the TPS, IAC, MAF, and air intake Temp sensor.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: Idle/Power Problem. [Re: Airdale73013] #760328 10/24/06 07:43 PM
sjs Offline OP
Where is the air intake temp sensor located?
Re: Idle/Power Problem. [Re: sjs] #760329 10/24/06 09:45 PM
A
In 1996 and newer it should be located in the top of the air-box.
Re: Idle/Power Problem. [Re: Airdale73013] #760330 10/24/06 10:48 PM
Everet Offline
FYI 1996 does NOT have a Air Intake Temp Sensor...at least the one I own and the one my brother has.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Idle/Power Problem. [Re: Everet] #760331 10/25/06 12:15 AM
sjs Offline OP
Dang. Mine is a '96.
Re: Idle/Power Problem. [Re: sjs] #760332 10/25/06 11:55 PM
sportagebandit Offline
MY 96 AINT GOT NO INTAKE AIR TEMPERATURE SENSOR EITHER.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: Idle/Power Problem. [Re: sportagebandit] #760333 10/26/06 01:30 PM
A
Ok my bad. Clean the other connectors and if necessary remove and clean the IAC, that cures a lot of idle, stalling, and erratic engine problems.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6288 MB (Peak: 0.7194 MB) Data Comp: Off Server Time: 2026-06-09 23:13:01 UTC
