Toyota axle knuckle rotation #760480 10/25/06 02:53 PM
I'm doing an axle rotation on my '84 Toyota axle so that I can get my pinion angle in a better position, and I heard from someone online that there are special u-bolts available to clear the differential housing on the passenger side to reattach the leaf springs to the spring perch. Does anyone know where I can get these u-bolts?
Re: Toyota axle knuckle rotation #760481 04/01/07 07:27 AM
8
84YOTA Offline
If your cutting and rotating the knuckles i believe you have to relocate the perches back atop but when you do check out marlins flip kit...www.marlincrawler.com
others:
www.allprooffroad.com
Theres more out there but these are just a few
84 toyota std cab with stuff on it
Re: Toyota axle knuckle rotation #760482 04/07/07 10:05 PM
4
4runnerchevy Offline
I rotated my front axle 12 deg. and just used a flip kit for the U-Bolts, I also recall 1 near the pumpkin giving me trouble, I just bent it and have never had a problem.
Re: Toyota axle knuckle rotation [Re: 4runnerchevy] #760483 04/07/07 10:13 PM
4
The bearing cups (top and bottom of your knucks)are on the same plane as your spring perches so just relocate the perches to the same plane as your rotated knucks. Make sure you use a good 4" pipe cutter and do not cut too deep.
Moderated by  4x4Wire, PHIL_
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5955 MB (Peak: 0.6524 MB) Data Comp: Off Server Time: 2026-06-07 10:35:20 UTC
