Page 3 of 3 1 2 3
Re: 2.6L not starting [Re: Troopersphere] #760584 11/12/06 09:55 PM
W
wontonsoup Offline
I have this problem with my amigo it start a few days ago when i decided to sale it,ran fine than after a test drive it just started dieing on idle and under gas,changed filter and did the engine check everything looks okay,can i safely say that the alt. is bad.and about how much does a alt. cost,somebody help me get it to stay running wife says its really got to go,its just been a pain in the butt dealing with this.thanks if somebody can help
Robert
Where do we go from here
Re: 2.6L not starting [Re: wontonsoup] #760585 11/12/06 10:36 PM
Troopersphere Offline
...can i safely say that the alt. is bad...
I don't think so. Does it stay running, but just badly ?
Alt problems usually show up as it will start, and run for a few seconds, then die. This is because the power to the fuel pump gets killed if the alt isn't working properly.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: 2.6L not starting [Re: Troopersphere] #760586 11/12/06 10:53 PM
W
wontonsoup Offline
on idle after starting for few seconds it stays running than dies,when on the gas itll stay running for a few minutes and then die,almost like something is clogged,but dont now enough about isuzu and dont want to spend a lot since im selling it.
Re: 2.6L not starting [Re: wontonsoup] #760587 11/13/06 06:07 PM
dozier13 Offline OP
check all of your vacuum hoses... my trooper would start for a few seconds then die before I had them all connected properly. also check your fuel filter that could be part of the problem
Re: 2.6L not starting [Re: wontonsoup] #760588 11/13/06 06:19 PM
dozier13 Offline OP
and yes, jeff, I got the liitle trooper all ready to go...looks rough but starts right up and drives just as good as it did when it had the old engine....now just gotta get a new muffler to keep it quiet but other than that its ready to roll...maybe I can finally squeeze in a camping trip up to tellico before the end of november! Thanks for all the help everyone!
Re: 2.6L not starting [Re: dozier13] #760589 11/13/06 08:46 PM
W
wontonsoup Offline
checked all the hoses and replaced the filter still does the same thing,i did do a k/n fitler on it could it be my mass air flow sensor,and is there a way to check to see if its good or bad.
Thanks
Robert
Re: 2.6L not starting [Re: wontonsoup] #760590 11/13/06 10:16 PM
dozier13 Offline OP
Im not sure how u would check your air flow sensor, but u may be able to find one cheap at the auto parts store. u said it was running not long ago? was that before or after u put the k&n air filter in? check your distributor cap, wires and plugs. I had a coil go bad on me once and it was the result of an engine that would start and then die within a few seconds check that also
Chris
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6243 MB (Peak: 0.7147 MB) Data Comp: Off Server Time: 2026-11-02 12:30:03 UTC
