Page 1 of 5 1 2 3 4 5
Skid plate blueprint, anyone? #760815 10/26/06 08:04 AM
Platarg814 Offline OP
So I just got my Sportage back from having a new fuel pump and tank put in (one of the few things I won't do myself) and had the shop leave the skid plate off because it rusted in half. Using what's left of the old plate and the old tank for dimensions, I am working on a 1/8 inch thick replacement. I'm not sure if I'll use steel or aluminum yet. Once it's done, I'll post pics on my site and if anyone wants the blueprints I can get them to you. Once this one's done I'll probably do the front one also since it's also rusted nearly through. Both will be much more "square" than the originals because angles are easier to make than radii, and they will have better liquid evacuation than original. Let me know your thoughts...
Re: Skid plate blueprint, anyone? [Re: Platarg814] #760816 10/26/06 02:53 PM
Hydra747 Offline
Very Very Very interesting! Do you know if you'll be doing a front skid plate (under the engine). Always wanted to do this but never made it. I think that it would be <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Skid plate blueprint, anyone? [Re: Platarg814] #760817 10/26/06 04:39 PM
logansportage Offline
Very interested! Would be nice to have the blue prints in something like CAD or Solid Works so we can take it to a CNC shop and have it machined at a very low cost.
Thanks a bunch!
Re: Skid plate blueprint, anyone? [Re: logansportage] #760818 10/27/06 04:04 AM
DEFBOY35 Offline
if i dont get mine done by time you have them ready i would be interested for sure.
im thinking of making them 3/16 steel myself.
the factory front one has a huge dent in it from a friendly encounter with a rock.
i will be doing the front pre runner skid, under engine skid and the fuel tank skids. once i get my new muffler, i might make a small skid for it. but trapped mud on the muffler may suck as well.
working on getting cad and solid works.
2000 SPORTY, DEF BOY customs, mmm....lockers, mmm... gears, mmm... double transfer case, mmm... stroker
http://www.cardomain.com/ride/2377991
Re: Skid plate blueprint, anyone? [Re: DEFBOY35] #760819 10/27/06 09:59 AM
flyboy367 Offline
i do mine old school. i just plop the old part down on some new metal and trace <img src="/forums/images/graemlins/smile.gif" alt="" />
id say if your looking to make your stuff "bullet proof" use steel diamond plate. 1/4" and thicker. i use a product from vht called epoxy coat. its a spray paint with a self primering etching epoxy. it seals metal so it doesnt rust. i find using a wire wheel to scuff up the part, then some paint thinner to clean it off makes it look best. the black is what i use. silver is decent and blue is a bit bright. the red looks like crap though.
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: Skid plate blueprint, anyone? [Re: flyboy367] #760820 10/27/06 12:11 PM
DamKia Offline
Kia Moderator
Only issue I have with using diamond plate (checker plate) for skid plates is the stuff by nature prevents slipping on its rough surface.
If you are going to use it, use it with the checker plate design up and away from the ground. Doesn't look as "cool", but is just as strong, and more functional...
Re: Skid plate blueprint, anyone? [Re: DamKia] #760821 10/27/06 01:12 PM
Dave Scott Offline
yeah, i'd stay away from the diamond plate too. 3/16" thick mild steel should be plenty strong enough (our frames aren't even anywhere close to that thick). i would not go to 1/4" for anything other than suspension bracketry, engine mounts, that sorta thing, something that takes a VERY high stress load. otherwise, it's just extra weight. the 1/8" will work for most situations, but if you're sitting there, pivoting on a rock with all the weight of the vehicle, it might bend just a hair. multiple bashings could booger it up good.
Re: Skid plate blueprint, anyone? [Re: Platarg814] #760822 10/28/06 01:51 AM
So, being a metalworker, I did a bit of research, and I decided to go with 1/8 inch flat steel plate, "hammered" (literally) for added hardness/strength, finished with the paint that was mentioned in the earlier reply. I'm still refining the design a bit in cardboard, and 2 front plates are officially in the works also; a stock size and a larger one covering the diff and such. I'll keep everyone posted and try to get this out reasonably quick.
Re: Skid plate blueprint, anyone? [Re: Platarg814] #760823 10/30/06 05:50 PM
Great! Thanks!
Re: Skid plate blueprint, anyone? [Re: Platarg814] #760824 11/05/06 02:21 AM
Cen_Tex_KIA Offline
I'm in for a new front plate if someone makes one........found that big rocks tear rusted metal.....imagine that! <img src="/forums/images/graemlins/shiner.gif" alt="" />
2000 KIA Sportage 4x4, Sadly Smushed! Now a 2001 Cheep Jerokee. 3" Rough Country Lift, 255/70/16 General AT2's
http://www.cardomain.com/ride/2292811
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6463 MB (Peak: 0.7677 MB) Data Comp: Off Server Time: 2026-05-29 22:25:30 UTC
