88 4runner rear end replacement
#761216
10/28/06 06:29 AM
hi ive got an 88 4runner v6 5speed and need to replace the rear end some dumb ass hit me and bent it. curious whether or not a 88 pickup rear end sould bolt up with no problems
Re: 88 4runner rear end replacement
[Re: dirtybikez]
#761217
10/28/06 05:39 PM
Yes it will. Any 84-95 4wd truck or 4Runner (up to '02' 4Runner) rear end will work.
Just make sure the ring and pinion is the same ratio (count the teeth)
[Re: dirtybikez]
#761218
10/28/06 06:30 PM
where are you located? little brother has a few...
[Re: Jake97T]
#761219
10/29/06 08:35 PM
im located in nor california and i think i found a rear end thanks
[Re: dirtybikez]
#761220
10/30/06 12:44 AM
should find yourself a TRD tacoma rear axle...
[Re: Adam F]
#761221
11/05/06 09:30 PM
so if the 4 banger has the smaller third member and the v6 has the bigger third member will it make a difference
[Re: dirtybikez]
#761222
11/05/06 11:12 PM
Generally speaking, no. They are interchangeable. The V6 third has larger bearings and pinion gear, and a little different carrier. You would never know the difference if I had not told you.
[Re: Adam F]
#761223
11/06/06 12:43 AM
thanks just clarifying that they are interchangeable and that they fit the same. thanks for all of your help
