Montero overdrive problem #761486 10/29/06 08:00 PM
7
777 Offline OP
I have a Montero '94 with 3.0 auto. Lately I noticed that transmission doesn't go into overdrive. The switch on shifter seems to work, because the OD light goes on and off if I play with switch, but no change in gear on highway speed. Does anyone know what could be the problem and is there any easy fix or something to try? Transmission oil looks clean, and doesn't smell burnt. All other gears shift good and don't slip.
Raider 6.0 V8 386hp, 397ft lb, 3?exhaust, Megasquirt ECU, EDIS ignition, Innovate LC-1 WB Lambda, NV4500, NP241 with JB conversions ?super short? SYE kit
Re: Montero overdrive problem [Re: 777] #761487 10/29/06 08:08 PM
FrankR Offline
Use the search - this problem has been beat to death a number of times. The most likely cause is the temperature switch on the thermostat water box.... ground the wire to the switch and see if the O/D works. If it does, the switch is bad..... or the thermostat isn't letting the engine come up to operating temperature.
Frank
Re: Montero overdrive problem [Re: FrankR] #761488 10/29/06 09:19 PM
7
777 Offline OP
Thanks FrankR, it was a temp switch connection problem. Working great now. I wish all the problems would be solved so easily...
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5940 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-09 23:32:40 UTC
