what solid axles to look for #761517 10/29/06 10:30 PM
muddermontero Offline OP
i was at the yard today browsing the sas vehicles and found plenty on wagoneers cherokees and a few others. from others experiances which is best for a gen 1 swap. 50 bucks for fronts and 75 for the rear is too cheap to ignor <img src="/forums/images/graemlins/cheers.gif" alt="" />
thanks again Tim
89 montero 4 door 3.0 auto bfg 33"x12.5 on 15x10
Flowmaster w/2.5 exhaust cranked w/ gen 2 springs
2" body lift no rust period but need paint
Re: what solid axles to look for [Re: muddermontero] #761518 10/30/06 12:42 AM
LandRaider Offline
Drivers side drop Wagoneer D44.
Re: what solid axles to look for [Re: LandRaider] #761519 10/30/06 12:52 AM
thanks for the confirmation. theres 2 out there that are clean so i might grab both sets. i guess im going to get them next weekend so here goes the sas swap. <img src="/forums/images/graemlins/cheers.gif" alt="" /> thanks again Tim
Re: what solid axles to look for [Re: muddermontero] #761520 10/30/06 01:33 AM
Baldy Offline
You can also use the high pinion Dana 44 out of a late 70's Ford F-150.
Re: what solid axles to look for [Re: Baldy] #761521 10/30/06 02:33 AM
cool although no 4wd older fords. i keep thinking i should just build my own chassis and drop the body on it.
Re: what solid axles to look for [Re: muddermontero] #761522 10/30/06 03:39 AM
sparkem Offline
Find a driver drop D60 and a rear 14Bolt. 1Ton stuff rocks. Also, I think the np231 bolts up to the gen1, you can get 4:1 and SYE. That would be a bad montero. I think I am going to do that one day to my Gen1.
Re: what solid axles to look for [Re: sparkem] #761523 10/30/06 04:49 AM
ok i like the 1 ton idea but i need translation on the rest. <img src="/forums/images/graemlins/confused.gif" alt="" /> i dont know what your saying but i like it! i am starting the sas asap so i can finish before jan 6. going to tennessee for some trails and i want to bring an unannounced suprise <img src="/forums/images/graemlins/evil.gif" alt="" />
Re: what solid axles to look for [Re: muddermontero] #761524 10/30/06 05:19 AM
sparkem Offline
Sorry, the NP 231 is a Tcase. You can search for it on here, i think it bolts directly up to the gen1 tranny. They came in a few vehicles, a lot of jeeps. The 4:1 for the t-case gears. SYE is slip yoke eliminator. I would only go 1 tons if you were doing some harecore rock crawling. 1tons are heavy and wide. But a montero on 1tons and 39in or 42in Iroks would be freekin awesome.
You could get a rear from a later model SR with 4.636 gears. It will bolt to your truck. Factory air locker, 1.4in shafts, 31 spline. And put a d44 front with 4.56gears and a locker, you should be good.
Re: what solid axles to look for [Re: muddermontero] #761525 10/30/06 06:39 AM
NathanC Offline
Perhaps it would be a good idea to mention that the Wagoneer axle would be a narrow track axle that would be a better match for the width of the vehicle.
But I guess if tire sticking way out on each side of your vehicle strikes you as cool, then go for the others.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: what solid axles to look for [Re: NathanC] #761526 10/30/06 01:01 PM
good point. considering its a road rider 90%. i really dont see how this is that expensive of a job to do. im estimating 1k will be the high side of the build. my brother in law and i will probably have it done in a couple weekends one i decide which setup to go with. there also is a decent chance ill just build a smallblock powered rolling chassis and drop the mony on it! that would be the better thing to do if i feel like calling a buddy who trained me when i worked at A.R.T. (applied racing technologies).
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6389 MB (Peak: 0.7616 MB) Data Comp: Off Server Time: 2026-10-24 02:36:47 UTC
