quick ecu question 86 pickup 22re #761560 10/30/06 01:24 AM
U
uglytruck Offline OP
the ecu that came out of my truck has the part # 89661-35060 and it has crapped out. i found one and the guy says it should work on my truck, but the part # on his is 89661-35070 ?
anyone know if it will work or is this guy full of sh*t?
thanks in advance!!!!
88 4runner sr5 v6
needs a lift!
-formerly 86yodaputruck
Re: quick ecu question 86 pickup 22re [Re: uglytruck] #761561 10/30/06 01:43 AM
4Crawler Offline
My '85 uses an 89661-35020 ECU and I tried an 89661-35070 and the engine fired up and ran with no error codes:
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Engine
Re: quick ecu question 86 pickup 22re [Re: uglytruck] #761562 10/30/06 03:46 AM
rednekbean Offline
Well i dont know the part number but i helped my budy peiece together the engine management on his 85 22-re. we used injectors out of an 92 and took the wire harness and ecu out of a 94 we found in a junk yard (totaly got a steal at 45 bucks for all of that and a few more various parts). once we got every thing figured out on that thing it ran like a rape-dape. all we did was 2.25 exhaust pipe and a flow master with stock manifold, and that thing would turn 38.5 sx like a set of 33's with all factory gears.
so it should work as we mixed parts from 85 clear through 94.
Nick
92' Pick-up, SAS, gears to make her crawl, 37's , bullet proof motor, and alot of time invested.
06 CRF450R one mean roost flinging machine
Re: quick ecu question 86 pickup 22re [Re: rednekbean] #761563 10/30/06 04:50 AM
dcg9381 Offline
Don't mix and match FI components of significantly differing years.. Some injectors were low impedance, some were high impedance.
"generally" speaking, if the ECUs will plug-in, they're close.. The best way to tell is to get a pin out from the FSM.... It tells you the functions of the pins on the ECU.
22REturbo.net
1988 4Runner
Re: quick ecu question 86 pickup 22re [Re: dcg9381] #761564 10/30/06 05:11 AM
U
cool, thanks for all the input!
i guess i'll give it a shot and see if it works!
88 4runner sr5 v6
needs a lift!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6057 MB (Peak: 0.6704 MB) Data Comp: Off Server Time: 2026-06-17 11:51:26 UTC
