Speedometer Not Working When First Starting Off
#761572
10/30/06 02:38 AM
94 Toyota Ex-Cab 4X4 3.0 Auto Electric Speed sensor My speedometer will not work when first starting truck. Odometer works, transmission shifts ok and no codes. After it does start it works fine until the next time it sits for awhile. Short stops don't seem to affect it only prolong stops. It first started working shortly after starting, within 2 or 3 miles but now sometimes it may go 30 miles before it will start working. After it starts there is no bouncing or erractic moves works smooth. Anyone ever had this problem. I figure speed sensor works correctly since odometer work when speedometer doesn't, transmission is getting readings from speed sensor because it shifts correctly and speedometer works correctly after it decides to start. It's sure puzzles me!! Any ideas??
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: Speedometer Not Working When First Starting Off
[Re: Smoke]
#761573
10/30/06 04:07 AM
Same thing happened on my wifes Honda and it was the speed sensor.
"Serenity through Sobriety"
[Re: OOP'S]
#761574
10/30/06 11:51 PM
Thanks for the response! Just couldn't figure out how the oddometer would work and transmission shift with bad sensor, but your not the first to tell me the same thing. Guess I'm just being hardheaded!! LOL
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5927 MB (Peak: 0.6462 MB) Data Comp: Off Server Time: 2026-06-17 12:58:44 UTCValid HTML 5 and Valid CSS
