No rear wiper or spray??? #761764 10/31/06 12:23 AM
2
2timer Offline OP
They don't work, and when I flip the switch, I can hear a "tick" coming from under the glove box along the right footwell. I replaced the Rear intermittent wiper relay which took the tick away. Still nothing. Fuse is good. And I also have a second used switch that yields the same results. Ideas? Thanks.
Re: No rear wiper or spray??? [Re: 2timer] #761765 10/31/06 12:49 AM
Fleabag Offline
I hear the whirrrrr noise when I press the spray button.. but I dont have a rear wiper... does that make any sense?
Strangers have the best candy
Re: No rear wiper or spray??? [Re: Fleabag] #761766 10/31/06 02:54 AM
Tag Offline
Mine did not work when I got the raider many years ago. I took the motor all apart and relubed all the stuff inside and it started to work.
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: No rear wiper or spray??? [Re: Tag] #761767 10/31/06 07:57 PM
DirtyOldTown Offline
Tag-I did the same thing. I took mine all apart and cleaned out the bore with a valve guide brush - works like a dog now.
What you guys need to do is see if you are getting voltage to the motor when you turn it on. If you are getting power but no movement you could probably "rebuild" yours. The washer pump/nozzle will be a different problem, but one step at a time I guess.
'91 LWB, 31x10.5s, KYBs, A/T "I look like Robert De Niro, I drive a Mitsubishi Pajero" - Billy Bragg (not the original lyrics, but that's how he sang it when I saw him in Dublin in '04)
Re: No rear wiper or spray??? [Re: DirtyOldTown] #761768 11/03/06 01:30 AM
Fleabag Offline
Uhm.. I have the spray set up and such, but I dont see where the rear wiper is or was... very strange.
Re: No rear wiper or spray??? [Re: Fleabag] #761769 11/03/06 03:04 PM
Odd - do you have a picture of the rear door? The wiper mounts right behind the spare tire. If the arm has been removed the stud wouldn't be in plain sight. Maybe all you need is an arm and a blade? What truck do you have?
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6089 MB (Peak: 0.6783 MB) Data Comp: Off Server Time: 2026-10-26 08:15:15 UTC
