Oxygen Sensor #762517 11/02/06 08:39 PM
sparky101 Offline OP
Does anybody know where the oxygen sensor connection is on a 1990 3.0 Montero,finding the sensor itself was easy but finding to where it plugs in at is driving me crazy.
Re: Oxygen Sensor [Re: sparky101] #762518 11/02/06 09:32 PM
JAVYPRO Offline
I found this, I am not certain and any of the guys withthe 3.0 can say if it is right but this is as per the repair manual:
[img][img:http://i79.imagethrust.com/t/460149/wiringdiagramo2sensor.jpg][/img]
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Oxygen Sensor [Re: JAVYPRO] #762519 11/02/06 09:49 PM
conner Offline
The manual shows it at the firewall towards the drivers side.
Two wire connector. one white and one black wires.
Over the hill but still climbing.
88 Montero 2.6L auto, manual hubs, cooling fan conversion gps,recurved distributor,LSD Diff.
Re: Oxygen Sensor [Re: JAVYPRO] #762520 11/02/06 10:05 PM
I can not make out the picture very well but thanks anyway and on the sensor itself ther are 4 wires going into the connector so I am still searching.
Re: Oxygen Sensor [Re: sparky101] #762521 11/02/06 10:41 PM
sparkem Offline
The wire goes over the tranny and plugs in on the driver side. One of the 2 plugs right by the t-case roll stop mount. Just above frame height.
Re: Oxygen Sensor [Re: sparkem] #762522 11/03/06 07:34 AM
52degrees Offline
That's where mine is too.
Sparky must have a Kalifornia model like mine. HO2S instead of O2. I haven't seen any Federal monteros, so I don't know for sure.
KG6VNX
Re: Oxygen Sensor [Re: 52degrees] #762523 11/03/06 12:36 PM
FrankR Offline
AFAIK, all of the '89s route the o2 sensor over the transmission to the driver side frame rail mount near the t-case.... a harness runs from the frame rail connection forward, then up and into the engine bay where it joins the run into the main harness. I suppose it's done that way to keep the harness away from high heat.
Frank
Re: Oxygen Sensor [Re: FrankR] #762524 11/03/06 03:33 PM
52degrees Offline
I meant the part about 4 wires instead of 2. Does yours have a heated O2 sensor?
KG6VNX
Re: Oxygen Sensor [Re: 52degrees] #762525 11/04/06 01:29 AM
FrankR Offline
Oh - sorry..... Mine is a 2-wire - non-heated... narrow-band.
Frank
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6277 MB (Peak: 0.7146 MB) Data Comp: Off Server Time: 2026-05-29 16:07:57 UTC
