Why is the reverse so lame? #762611 11/03/06 04:11 AM
9
94redrodeo Offline OP
I took the beast wheeling this weekend and I am happy with it but there is one major problem.
Reverse sucks what is the reverse ratio in the 4l3oE .80
<img src="/forums/images/graemlins/angry.gif" alt="" />
I was in 4 low and was unable to back up over a rock once it just sits there and revs to 2000 and does nothing in first it will smoke all four tires trying to climb a rock.
What do I need to do I'll end up on a trail and be in trouble because reverse is to weak.
Put it in tera low 3.07:1's but will that be enough
throw the 4l30e in the garbage and do a MUA5
put in a 700r4 with a D300
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Why is the reverse so lame? [Re: 94redrodeo] #762612 11/03/06 06:11 AM
lttlbddy Offline
Not sure if the Isuzu's are the same but looks more like 2.00:1 for reverse.
A locker of some sort will help in both directions. If you are revvin gup to 2000 rpm, it sounds more like a traction issue than a tranny issue.
Gear Ratios:
2.40:1 1st gear
1.479:1 2nd gear
1.00:1 3rd gear
0.723:1 4th gear
2.00:1 reverse
Optional Gear Ratios:
2.86:1 1st gear
1.62:1 2nd gear
1.00:1 3rd gear
0.723:1 4th gear
2.00:1 reverse
Re: Why is the reverse so lame? [Re: lttlbddy] #762613 11/03/06 06:15 AM
9
its not a traction issue that just the stall on the torque converter it was not moving the tires in reverse it doesn't have the power to spin the tires in reverse because reverse is geared to tall
Re: Why is the reverse so lame? [Re: 94redrodeo] #762614 11/03/06 01:18 PM
Rodeo Guy Offline
This is a common complaint for the 4l30. It has a bad reverse ratio. I've also heard something about the reverse gear doesn't get as much line pressure or doesn't have as many clutches, I forget. Get teralows. Or 5.38s. Or an mua5, then you can back over stuff, and you don't have to worry about it kerploding.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Why is the reverse so lame? [Re: Rodeo Guy] #762615 11/03/06 04:11 PM
lttlbddy Offline
My bad, I saw the "smoke all four tires" comment and didn't realize that he was referring to forward.
The difference between forward and reverse ratio is not that great, I am surprised that there is that big of a difference in performance.
Lowering the t-case gearing will not change the symptom, it will just allow the torque converter to lock up at a lower SPEED (not RPM).
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.6077 MB (Peak: 0.6734 MB) Data Comp: Off Server Time: 2026-06-20 17:50:36 UTC
