transfer case ball detents #762861 11/04/06 08:12 PM
SPRaYeD Offline OP
91 trooper, 2.8, 5 speed. Does anyone have any suggestions for getting the detent balls out of the transfer case? I tried a magnet but it's not strong enough. I'm just getting frustrated now. Any help will be appreciated.
Re: transfer case ball detents [Re: SPRaYeD] #762862 11/04/06 08:30 PM
strawmyers Offline
Isuzu Moderator
Are you taking the case apart anyway? When I was tearing my case apart, I didn't have a magnet thin enough to fit down into the holes. Since I was taking the shift rails out anyway, I just took them out first and then the detent balls could be pushed down and came out through the passages in which the rails sit.
Sean Strawmyer
Re: transfer case ball detents [Re: strawmyers] #762863 11/04/06 08:58 PM
SPRaYeD Offline OP
no just replacing the balls, springs, and caps.
i have a shifting problem where it doesn't like to stay in gear. i'm hoping that this solves the problem but i don't think it will solve anything.
Re: transfer case ball detents [Re: SPRaYeD] #762864 11/04/06 09:50 PM
SPRaYeD Offline OP
filled the holes with carb cleaner and blew them out with the air gun...should have thought of that earlier
didn't solve the problem...not to my surprise
Re: transfer case ball detents [Re: SPRaYeD] #762865 11/04/06 11:19 PM
RubyTrooper Offline
Doing the TeraLow install, huh. <img src="/forums/images/graemlins/shiner.gif" alt="" /> I just did this last weekend. Same truck, year, and engine. My magnetic pickup tool could not lift the ball either. The magnet was not strong enough. However, I did go to HomeDepot and purchase a magnetic pickup with a neodymium magnet. VERY STRONG pull. Like this one:
When I came back to the wrenching party, my frustrated friends (couldn't get that *@%! ball out either) had my transmission ripped (Terry, you know who you are!!!! <img src="/forums/images/graemlins/evil.gif" alt="" />) from my Trooper! <img src="/forums/images/graemlins/zombie.gif" alt="" /> The first time that I placed the small neodymium magnet pickup in the ball channel, it picked it right up!
Good luck!! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Isuzu Trooper, '91, 2.8L, 3" PA BL, coil sprung SAS, OX locker front, Detroit back, 5.38 gears...
Ruby's got a theme song!!! Sing-a-long
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6058 MB (Peak: 0.6698 MB) Data Comp: Off Server Time: 2026-05-30 02:24:32 UTC
