Well, the fun just never ends... I ordered a Denso fuel pump and a tank gasket, and was ready to do the job today. After consulting with a trusted mechanic, I decided I did not need to drain the fuel tank, or drop the tank.
Getting the return-side line off was a simple matter of removing the hose clip, and patiently convincing the rubber hose off the connector. Then came the supply-side. According to the FSM (at least the way
I read it) the line side is the stationary side, and the flare nut on the metal pipe to the pump is the rotating side. I sprayed the whole connection down with PB Blaster several times and let it sit, and then put my two wrenches on the nuts, and tried to turn the flare nut while keeping the hose-side stationary. Uh, no. Not budging. Then I noticed fuel dribbling down where the pipe went through the plate that mounts to the fuel tank. <img src="/forums/images/graemlins/scared.gif" alt="" /> Closer inspection revealed that the tube had a hairline crack about 1/8" above the mounting plate. OK, this just got exponentially more aggravating... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> A little more muscle and the connection broke free -- well, the supposedly-stationary side did. Since there was no way I would re-use that supply pipe, I just broke it off and unscrewed it from the line.
Examining the flare nut makes me wonder if someone brazed it on trying to deal with a leak or I just misunderstood the FSM, because that sucker looks like one solid connection:
So now I have one of these:
on order from msrecycling, and I'll continue with the saga next week after it gets here. At least I was able to get the pump out! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Oh, and regarding the 10+ volts... I
did jumper the battery (measured @ 12+ volts) directly to the fuel pump via the test connector per the FSM, and there was no noise, so the fuel pump is definitely bad.
