Cruise control & misc ?'s #763147 11/06/06 05:10 AM
RichieRich Offline OP
Greetings all,
I have just recently purchased this 96 4x4 with the extra cab or what ever ya call it. this is mainly my work truck and I have started to find some weird things going on.
with the c/c engaged it will just shut off, loosing its pgm and all??? when making a sharp turn and say going over a bump I get this loud snapping or cracking sound like something twisting. I don't remember these things in my old nissan. and I have been in full size trucks since 1989,with no things like these.
If anyone has ideas ???.
Rich
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763148 11/06/06 05:24 AM
W
Winkel1 Offline
The loud creaking and popping is the steering travel limiters. There is a mechanical stop on the spindle where it hits the cross member. They came stock with plastic caps but they don't last. Smear a small dab of grease on the flat stops. It really does make a difference. It took me four years to figure that one out. On the C/C, I can't help you.
Winkel
98 T100 SR5 4WD
Rhino Liner
Warn Hubs
Mostly Stock
Re: Cruise control & misc ?'s [Re: Winkel1] #763149 11/06/06 03:19 PM
Thanks for the tip Winkle.
and for not holding me out for 4 years on it.
Rich
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763150 11/06/06 10:49 PM
wsquaredodie Offline
The CC prob sounds like the "cancel" program is geting engaged. When you are making the moves described it may be the gas pedal cable is flexing (indicating you want to accelerate) the brake sensor is activated (you want to stop) or there is something going on in the steering wheel circuit related to the cancel button. Spend the time to do the FSM download and you can get all the electrical diagrams.
trafdlo
Re: Cruise control & misc ?'s [Re: wsquaredodie] #763151 11/07/06 12:09 AM
ErikB Offline
Toyota Moderator
Does the CC shut off completely (light in dash goes out), or does it just disengage? Both the clutch and brake pedal switches could disengage it and a minor adjustment might fix it.
http://home.4x4wire.com/erik
Re: Cruise control & misc ?'s [Re: ErikB] #763152 11/07/06 12:27 AM
Good Q Erik. Forgot to ask about the dash light...
trafdlo
Re: Cruise control & misc ?'s [Re: RichieRich] #763153 11/07/06 02:45 AM
mikek Offline
Just a thought...When I first got my T100 the cruise control wasn't working at all. Doing my usual "new to me" vehicle inspection I noticed that the brake fluid was a tad low. I topped it off and...cruise control was back. Not a problem since then.
Mike
'96 T100 SR5 XtraCab 4x4 5spd
'78 Honda CB750F
Re: Cruise control & misc ?'s [Re: mikek] #763154 11/07/06 02:53 AM
All,
the light stays on, I just have to re-engage it. sucks when you are on a nice power run up a 7% grade then wammm no c/c.
it does it whenever no rime or reason no turning or bumps. I have tried to see if I could link it to something like if I put a turn signal on or hit the brakes.... BUT it just does it in the middle of steady crusing?????
Rich
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763155 11/07/06 03:49 AM
kewlynx Offline
Check to see if you have any brake lights, or at least to see if the 'stop' fuse is blown. Without the brake signal, CC goes a little wonky too.
Inspect your vacuum lines.
The troubleshooting section for the CC in the FSM is pretty extensive, even for the older trucks.
**ubi apis- ibi salus**
Re: Cruise control & misc ?'s [Re: RichieRich] #763156 11/07/06 03:19 PM
On the subject matter of vacuum lines....At about 10 years a lot of the neoprene lines harden and crack, especially those close to hot engine parts. Here's an old trick - a PITA but it works. Pop off the lines one by one. Snip off a quarter inch or so and put the line back on. Doing so gets you into "new" hose softness and inner diameter. Look close for cracking when bending. If the lines show surface cracks, replace even if they are not leaking - they will.
trafdlo
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6467 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-06-09 21:38:33 UTC
