Re: Cruise control & misc ?'s [Re: wsquaredodie] #763157 11/07/06 07:55 PM
MR24Shoe Offline
the sounds when turning sharp could be the steering relay rod recall?
1996 Toyota T100 4x4 SR5 V6
1971 Datsun 240Z
Re: Cruise control & misc ?'s [Re: MR24Shoe] #763158 11/10/06 06:24 AM
RichieRich Offline OP
thanks for the idea everyone, I will try to find time to check them out. it is ELK season now and I have to double,triple check all my gear. the c/c is okay for the time being. I sure like the little T100. I am getting like 21+ MPG
Rich
07 Mercedes GL 450
93 Freightliner FL 70 C/C 8.3 cummins, allison auto
96 Toyota T100 4x4 xtra cab v6 5 spd
05 KZ 41kx2 NV Toy Hauler 14'garage 43'of 5r
04 polaris 500 HO 50th year limited
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763159 11/13/06 10:48 PM
UPDATE,
ok after paying attention this time in more detail. the C/C only shuts off when I am in 5th gear and going up a major grade, like a 6 or 7% hill after a while bang. so I am thinking it is maybe some sorta speed/RPM thing because if I put into 4th and run a hill it will hum in C/C the whole hill.
Rich
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763160 11/13/06 11:37 PM
ErikB Offline
Toyota Moderator
The CC is set up so that it kicks off if the speed drops 10mph or so below the set point (truck can't maintain speed in that gear). Is that what's happening? Owners manual has the details.
Make sure the actuator is pushing the pedal all the way down when it needs to. If the cable is too loose or something the actuator might not be able to put the pedal to the metal.
http://home.4x4wire.com/erik
Re: Cruise control & misc ?'s [Re: ErikB] #763161 11/14/06 06:17 AM
I am kinda thinking it is normal for this to happen, now that I have played around with it. thanks for the help
Rich
07 Mercedes GL 450
02 polaris 500 HO
51 willys M38
56 Dj
Re: Cruise control & misc ?'s [Re: RichieRich] #763162 11/17/06 07:58 PM
I also, have a 96 t100 in red just like RichieRich and have a problem with the c/c. The difference with mine is on flat land and c/c running, the truck "lurches" and the overdrive disengages. Any suggestions? <img src="/forums/images/graemlins/nana.gif" alt="" />
Re: Cruise control & misc ?'s #763163 11/20/06 12:41 AM
N
Nicculi Offline
just so you know the c/c reads off the speedo head, if it bounces your cruise will surge
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6191 MB (Peak: 0.7135 MB) Data Comp: Off Server Time: 2026-11-02 12:28:40 UTC
