Page 3 of 3 1 2 3
Re: Gearing questions? [Re: half_fast] #763336 01/10/07 03:21 PM
grandeyota Offline
I'm running a 4.88 with 33's and I checked what the speedometer says compared to the GPS. Here is what I got(5th gear 22re w56):
RPM...Speedo...GPS
3000..68..........60
3200..73..........66
3400..78..........70
3600..84..........76
Fur clog in the sausage grinder
Re: Gearing questions? [Re: grandeyota] #763337 01/10/07 05:16 PM
84toyota Offline
One more question for you guys... is there a difference between the V-6 4.88 factory third member [color:"red"]WITH ABS Vs. WITHOUT ABS [/color]? Would that even matter if all you are dealing with is the third member? If there are differences, what are they? The only reason I ask is because there seems to be an abundance of thirds with ABS and not very many without...
Thanks,
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: Gearing questions? [Re: 84toyota] #763338 01/10/07 05:27 PM
4Crawler Offline
The ABS version just has he speed sensor for the ring gear on the rear axle for the ABS controller. Easy to cut off the wires and/or pull and plug the sensor hole.
Re: Gearing questions? [Re: grandeyota] #763339 01/11/07 05:48 AM
RatLabGuy Offline
RPM...Speedo...GPS
Looks to me like a perfect match, just like the math predicts.
Any gear ratio offset would cause the error to grow with speed (constant % error).
Looks to me like somebody has done a "poor-man's correction" on this truck, lol. I did this by moving the needle.
FWIW, I'm using 4.88s and 32s on an A/T. Find it's a good match. Math works out to stock ratio, although Toyota put 31s on this combo making that OE setup a little overgeared.
Question Reality.
Re: Gearing questions? [Re: RatLabGuy] #763340 01/11/07 03:52 PM
grandeyota Offline
The speedometer and GPS seem to match right up when I have the 35s on there (with 4.88).
Go figure.
Re: Gearing questions? [Re: grandeyota] #763341 01/11/07 06:57 PM
RatLabGuy Offline
Go figure.
Hee hee, you must have gotten one of those rare non-linear gear sets. Them's a rare find!
Question Reality.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6183 MB (Peak: 0.7049 MB) Data Comp: Off Server Time: 2026-05-30 01:15:03 UTC
