Leaking coolant #763395 11/07/06 07:02 PM
sled207 Offline OP
Hey Guys,
1990 Montero 3.0L. When I got this rig it had a bad intake gasket. Replaced the gasket, but it is still leaking. Water pools up on the engine block under the intake. Do ya'll think the gasket is still leaking, or could it be the metal line that sits on the block in that same location? That line connects to something at the front of the engine(maybe the back of the water pump) and looks like it ties into part of the haeter circuit at the rear of the engine. Maybe a bad o-ring or something?
Re: Leaking coolant [Re: sled207] #763396 11/07/06 07:43 PM
Water pump tube rear oring (the one you suspect) or further leak in the lower intake gasket. That one is tricky to seal.
Re: Leaking coolant [Re: fasteddy] #763397 11/07/06 07:53 PM
sled207 Offline OP
How do I change the o-ring? I tried tugging on the metal line when I changed the gasket the first time, but it seemed stuck pretty good. Does that line just pull out with more force, or is there some trick to getting it out?
Lower intake gasket? Where is that?
Re: Leaking coolant [Re: sled207] #763398 11/07/06 08:41 PM
sparkem Offline
To pull that pipe out of the water pump you have to unbolt it from the back of the pass side head.
Re: Leaking coolant [Re: sparkem] #763399 11/07/06 10:31 PM
sled207 Offline OP
After unbolting the line from the head, does it just "magically" pull out of the water pump?
Is the o-ring a dealer part or will one work from the local auto store?
Re: Leaking coolant [Re: sled207] #763400 11/08/06 04:23 AM
sparkem Offline
Bolt is kinda hard to reach. Once it is out, the pipe just pulls out. Unless it somehow seized together.... You probably need to get that O ring from the dealer.
Or you could pull the water pump off of the front, more work.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6095 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-06-23 21:15:07 UTC
