Driveline Clunk When Starting #763533 11/08/06 03:51 AM
KLRTom Offline OP
My 1998 Cherokee 4WD is making a clunk in the rear when I start up from a stop. It almost feels like the wheels are loose on the rear hubs. All lug nuts are tight, the U joints don't appear to be bad. I searched the archives but couldn't see where this one has been posted before. Anybody have any ideas?
Re: Driveline Clunk When Starting [Re: KLRTom] #763534 11/08/06 04:31 AM
BigJim Offline
Could be a spring.. specially a hanger. Possibly a tranny mount. You need to put the vehicle in neutal and get under it and give the u-joints some real pushing and pulling to verify no looseness at all in any direction.
Re: Driveline Clunk When Starting [Re: BigJim] #763535 11/09/06 03:57 AM
NCBBA2358 Offline
In addition to BigJim's thoughts, put the Jeep up on jack stands, on the suspension , not necessarily the frame. Then, when you feel safe enough, squat down at each tire and yank it in and out and try to push/pull from side to side and see if you feel any movement. Then try to rotate the wheel and look for slack or delay in your drive shaft turning....
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Driveline Clunk When Starting [Re: NCBBA2358] #763536 11/10/06 09:21 AM
derangedcj Offline
Another thing i would check are the wedge retaining bolts. Bolt of mine has snapped. Your could literally go shake the axle up and down with out trying. <img src="/forums/images/graemlins/kewl.gif" alt="" />
83 CJ-7 3 in suspension. All problems currently fixed. Just Everyone Elses Parts. JEEP
Re: Driveline Clunk When Starting [Re: derangedcj] #763537 11/12/06 03:08 AM
KLRTom Offline OP
Thanks to all for the suggestions. I'll check these out tomorrow. Does anyone have an idea how much play there should be in the driveshaft? What I mean is, how much should you be able to rotate it before all the play is taken up by the differential? It seems like I can turn it about 1/8 of a turn.
Re: Driveline Clunk When Starting [Re: KLRTom] #763538 11/12/06 03:53 AM
BigJim Offline
Yes there is play between the pinion and the ring gear.. play is normal. 1/8" is 12.5* that may be a bit large but prolly your "clunk" is not in there.
Re: Driveline Clunk When Starting [Re: KLRTom] #763539 11/12/06 08:55 AM
BobRowe Offline
There is likely to be some movement in the differential, and maybe some in the transfer case/transmission. But there should be absolutely no movement in the driveshaft itself. If there is, one or both U-joints need to be changed, or one of the yokes is stretched or worn, or the U-bolts or strap bolts are loose.
Re: Driveline Clunk When Starting [Re: BigJim] #763540 11/13/06 01:05 AM
KLRTom Offline OP
Actually, the play is about 1/8 of a complete rotation of the driveshaft. More like 1 1/2 inches. Unfortunately, there is no play in the u joints. I'm thinking it seems more like the pinion.
Re: Driveline Clunk When Starting [Re: KLRTom] #763541 11/13/06 03:09 AM
rangermaniac Offline
How many miles are on it
Re: Driveline Clunk When Starting [Re: KLRTom] #763542 11/13/06 03:22 AM
any play in the cross shaft in the diff?
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.004s) Memory: 0.6353 MB (Peak: 0.7423 MB) Data Comp: Off Server Time: 2026-06-10 04:15:28 UTC
