Anyway, the plane flies off the conveyor belt as pretty as you please - so long as the wheel bearings don't seize. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Frank
Thank you Frank. Anyone who does not understand this needs to REREAD the post, and think about it for a while. Its stated VERY clearly how, and why the plane will be able to lift off, and fly away.
Anyone who doesn't see this needs to be mercilessly beat about the thing that's supposed to be a head on their shoulders... <img src="/forums/images/graemlins/lol.gif" alt="" />
Come on over...
<img src="/forums/images/graemlins/smile.gif" alt="" />
I believe this may be the problem of some to comprehend the terms of the original word problem. My answer still stands with the understanding that
A) The experiment begins with zero work (aircraft engines off, conveyor belt off)
B) No wind
C) Zero friction in the wheels
D) Ground speed is understood as relative to a point on the ground - not on the conveyor
E) Infinite technology to commence the experiment I.E. (and by far the most important) the conveyor belt moves exactly to the induced speed of the plane at precisely the same time.
Gravity holds the plane to ground. The free spinning wheels are a conveyor in themselves - allowing the plane to create forward motion without (in our case) any friction.
In our windless scenario the thrust has to propel this object forward to take off speed -
which is also ground speed. Now remember the original post? The conveyor matches the speed of the plane. All you Yes-It-Willers are assuming that at some point the planes thrust overpowers the the speed of the belt. It doesn't. It aint going anywhere. And in fact the conveyor will hardly move.
Again I defer to my R/C airplane experiment -
1) Hold it above your head at full throttle and let it go - that thing on your head will be mercilessly beat <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
2)Now step on a 500ft treadmill, power it up and start running matching speeds so you remain stationary relative to a linear space (on the ground NOT the treadmill), hold the plane above your head and gently let go - again you will feel pain.
3)Now get on it again. Put the treadmill on slow and start running. Eventually if you are fast enough you will gain enough speed over the treadmill to provide enough airflow over the wings to produce lift - the ground speed (speed relative to the ground
NOT the treadmill) is equal to the TakeOff speed. If you let go the plane will fly away.
BUT #3 IS NOT THE SITUATION POSTED IN THE PROBLEM This riddle is #2.
If I still haven't converted you there is no hope.
There is nothing new under the sun Can we beat 400 pages? <img src="/forums/images/graemlins/pfft.gif" alt="" />
