Page 6 of 16 1 2 4 5 6 7 8 15 16
Re: OT Plane on a Treadmill [Re: LandRaider] #763594 11/09/06 05:24 AM
Oyaji_Jon Offline
Anyway, the plane flies off the conveyor belt as pretty as you please - so long as the wheel bearings don't seize. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Frank
Thank you Frank. Anyone who does not understand this needs to REREAD the post, and think about it for a while. Its stated VERY clearly how, and why the plane will be able to lift off, and fly away.
Anyone who doesn't see this needs to be mercilessly beat about the thing that's supposed to be a head on their shoulders... <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OT Plane on a Treadmill [Re: Oyaji_Jon] #763595 11/09/06 05:26 AM
52degrees Offline
If they don't understand, it's probably already happened <img src="/forums/images/graemlins/lol.gif" alt="" />
KG6VNX
Re: OT Plane on a Treadmill [Re: 52degrees] #763596 11/09/06 05:26 AM
Jamez Offline
Well ain't that somethin <img src="/forums/images/graemlins/ignore.gif" alt="" />
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: If you were traveling the speed of light [Re: Jamez] #763597 11/09/06 06:06 AM
Kevin C Offline
If you were traveling at the speed of light would your headlights still work? How about your wipers?
Kevin <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: If you were traveling the speed of light [Re: Kevin C] #763598 11/09/06 06:10 AM
Roll_me_over Offline OP
Define still work. Yes they would still operate but would they illuminate your path in front of you? And your wipers would freakin fly off the car along with the paint...lol
02 Ford F-250 4X4 PSD...zero body damage
67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: If you were traveling the speed of light [Re: Kevin C] #763599 11/09/06 06:14 AM
Neo Offline
Get serious - it would depend if you were going the speed of light on a treadmill! Then, your headlights would work fine.
1991 JDM SWB Pajero TD - Sold....
1997 Dodge Ram 2500 Cummins 4x4
Re: OT Plane on a Treadmill [Re: Jamez] #763600 11/09/06 06:17 AM
Oyaji_Jon Offline
The way I see it, the problem can be broken into three parts, none of which are equationally connected to each other. That of the plane's fuselage and it's relationship to the air, that of the wheels and their relationship to the conveyor and that of the fuselage and its relationship to the wheels. To simplify the problem, lets consider the wheel bearings to be frictionless (no heat/can't lock up/cannot induce movement on their own accord).
Part I: The wheels/fuselage relationship.
The wheels sit under the plane and provide a "frictionless" support between the fuselage and the ground. Since the ground is "stationary" and the plane must move to attain lift, the wheels break all physical connection between the fuselage and the ground while it is overcome by gravity (lift comes later).
Part II: Wheels/Conveyor relationship
Consider that the wheels have perfect physical connection to the conveyor through friction (no slip). According to Newton an object at rest remains at rest unless acted upon by an outside force. So, when the conveyor moves, the wheels turn, but, because of the fricionless bearings, have no effect on the fuselage. This induces relative motion between the conveyor and fuselage, but no true motion (speed over geographical ground) or relative motion through the air (still no lift).
Part III: Fuselage/Air relationship
The fuselage is connected to the engine. The engine has an output shaft that is connected to a propeller. The shaft is coupled to the engine by another frictionless thrust bearing. This means there is a physical connection between the propeller and the fuselage. When the propeller turns, it cuts the air causing a low pressure area to form on the front of the propeller and a high pressure area on the rear. Because of this pressure differential, the propeller pulls forward taking the fuselage with it.
The outcome:
Because the propeller is now pulling the previously stationary object forward, it is achieving relative motion with the motionless air (no wind) and static geography. As the plane moves forward and relative motion between the fuselage (with wings) and air increases speed, vertical lift occurs and takeoff is achieved. The key is that the wheels do nothing in this case except keep the fuselage from making physical contact with the conveyor while lift has not overcome gravity.
I hope I made my thoughts clear as mud...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OT Plane on a Treadmill [Re: Oyaji_Jon] #763601 11/09/06 06:20 AM
Oyaji_Jon Offline
Oh, looky there. As I was exposing my mental retardation by typing that long explanation, the conversation took another turn. I'm a total De-De-Deee... <img src="/forums/images/graemlins/notooth.gif" alt="" />
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OT Plane on a Treadmill [Re: Oyaji_Jon] #763602 11/09/06 06:56 AM
Happens to the best of us...
Re: OT Plane on a Treadmill [Re: Oyaji_Jon] #763603 11/09/06 07:14 AM
bretwalda Offline
Frank
Come on over...
<img src="/forums/images/graemlins/smile.gif" alt="" />
I believe this may be the problem of some to comprehend the terms of the original word problem. My answer still stands with the understanding that
A) The experiment begins with zero work (aircraft engines off, conveyor belt off)
B) No wind
C) Zero friction in the wheels
D) Ground speed is understood as relative to a point on the ground - not on the conveyor
E) Infinite technology to commence the experiment I.E. (and by far the most important) the conveyor belt moves exactly to the induced speed of the plane at precisely the same time.
Gravity holds the plane to ground. The free spinning wheels are a conveyor in themselves - allowing the plane to create forward motion without (in our case) any friction.
In our windless scenario the thrust has to propel this object forward to take off speed - which is also ground speed.
Now remember the original post? The conveyor matches the speed of the plane. All you Yes-It-Willers are assuming that at some point the planes thrust overpowers the the speed of the belt. It doesn't. It aint going anywhere. And in fact the conveyor will hardly move.
Again I defer to my R/C airplane experiment -
1) Hold it above your head at full throttle and let it go - that thing on your head will be mercilessly beat <img src="/forums/images/graemlins/butwiggle.gif" alt="" />.
2)Now step on a 500ft treadmill, power it up and start running matching speeds so you remain stationary relative to a linear space (on the ground NOT the treadmill), hold the plane above your head and gently let go - again you will feel pain.
3)Now get on it again. Put the treadmill on slow and start running. Eventually if you are fast enough you will gain enough speed over the treadmill to provide enough airflow over the wings to produce lift - the ground speed (speed relative to the ground NOT the treadmill) is equal to the TakeOff speed. If you let go the plane will fly away.
BUT #3 IS NOT THE SITUATION POSTED IN THE PROBLEM
This riddle is #2.
If I still haven't converted you there is no hope.
There is nothing new under the sun
Can we beat 400 pages? <img src="/forums/images/graemlins/pfft.gif" alt="" />
concreteprinter.com
PHP: 7.4.33 Page Time: 1.906s Queries: 16 (0.005s) Memory: 0.6599 MB (Peak: 0.7869 MB) Data Comp: Off Server Time: 2026-05-29 22:33:02 UTC
