Re: Can you identify this part??? [Re: Rauch_Off_Road] #763747 11/09/06 01:42 AM
OOP'S Offline
Easiest way to work on that crap back there, take the hood off.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Can you identify this part??? [Re: OOP'S] #763748 11/09/06 02:05 AM
Rauch_Off_Road Offline OP
Here's my deal. I'm having a problem above 180 degrees the hotter my engine gets the worse my idle gets till the temp reaches 210/220 and then it dies.
(aka suprathepeg, aka Sean)
Re: Can you identify this part??? [Re: Rauch_Off_Road] #763749 11/09/06 09:21 PM
dogtoy Offline
Just remove the plenum. I broke mine during the rebuild somehow also. This is a a switch that is activted and deactivated through water temp. It is what controls the vacuum to suck from the charcoal canister or not. If it is broken and opens it would definately effect your idle. The top goes to your canister and the bottom connects to the air intake.
2014 FJ
Re: Can you identify this part??? [Re: dogtoy] #763750 11/12/06 02:40 AM
N
nlexpcoa Offline
I found mine was broken one day, I went to remove it, but it would not budge. Rather than snap it off I just bypassed it. I ran the hose from the charcoal canister past the valve and to the metal fitting on the other side. No porblems at all. Same fuel mileage.
NL
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6069 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-06-17 01:54:07 UTC
