Seeing what options are out there for lifting 95 Passport... #763751 11/08/06 06:05 PM
thecure7 Offline OP
Hey guys,
My wife's 95 4WD passport is due for new shocks and so I had already been thinking about going ahead and putting a mild lift.
What options are out there and what upgraded tire sizes can I fit under the truck when it is finished?
Ran a search but didn't find too much in regards to 95 passport/rodeo lifts.
Thank guys! <img src="/forums/images/graemlins/kewl.gif" alt="" />
1992 Land Rover Range Rover 3.9L V8
1995 Honda Passport V6 4x4
1989 Isuzu Trooper 2.8L V6 Manual ~Sold
Re: Seeing what options are out there for lifting 95 Passport... [Re: thecure7] #763752 11/08/06 06:36 PM
Bansil Offline
It will be almost exactly like your 89 Troop.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Seeing what options are out there for lifting 95 Passport... [Re: Bansil] #763753 11/08/06 07:46 PM
thecure7 Offline OP
Ahh, ok cool then. Hadn't really looked under it since we bought it and at the same time moved away from my shop. Thanks for the info.
Are there any particular kits that are made? With some research I found a Calmini, are there any others?
Re: Seeing what options are out there for lifting 95 Passport... [Re: thecure7] #763754 11/08/06 09:17 PM
Smiley Offline
I promise that I'm not trying to be sarcastic... But how can anyone have over 200 posts at 4x4Wire (almost every single one of them in the Isuzu Talk and Tech forums) and yet somehow still not know about Matt Brown and Independent4x?
Give him a call -- He's got whatever you need (and then some <img src="/forums/images/graemlins/kewl.gif" alt="" /> )
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
Re: Seeing what options are out there for lifting 95 Passport... [Re: Bansil] #763755 11/09/06 12:47 AM
Jonesy Offline
Bansil
Not almost...it is the same(as far as lift goes) Torsion Bar crank, extended shackles, add-a-leaf, etc. It is simply the same basic setup for lifting.
It can be pieced out or you can buy a kit. The basic kit at Indy4X would easily apply for the 95 Passport, as it would for your Trooper.
As for tire size, the most common tire with a 3" SL is a 265/75/16 tire. If you have 15" rims you could go as high as 32x11.5 You can squeeze 285/75 on there, or a 33x12.5, it just needs to have the fenders cut. So simply fitting tires stick wtih 265/75
'97 Rodeo
3.2L V6
DOR 3" lift, 3"BL, DOR Boulder Bars, Tera-Low's, 33x10.5,Surco Safari Rack, Cobra CB, Rancho 9000's....andnNow with Half-Doors for the summer
Re: Seeing what options are out there for lifting 95 Passport... [Re: Jonesy] #763756 11/10/06 03:31 PM
thecure7 Offline OP
Thanks for the response guys. I have been gone awhile and busy with work so the truck has been on the backburner besides using it as transportation.
When I do have time, my dad and I have been working on his Rods, so not been in the lingo for so long, a guy forgets. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Indy4x was in my head, just couldn't remember the name. I appreciate all the responses. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Seeing what options are out there for lifting 95 Passport... [Re: thecure7] #763757 11/13/06 04:06 PM
icu_runnin Offline
Let me know when your ready to go out and use that thing off the pavement again. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
92 Galant VR4 #501/1k - Turbo, All Wheel Drive with 4 wheel steering - Money eatin toy
89 Isuzu I-Mark RS sings to 7800 RPM - Daily Driver
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6236 MB (Peak: 0.7151 MB) Data Comp: Off Server Time: 2026-05-26 03:48:11 UTC
