rebuild of a 86 4runner 22re motor #763800 11/08/06 09:43 PM
V
veach Offline OP
so i started my rebuild the other day and so far everything is not going to plan. when i was unhooking most of my electrical connectors they broke due to the fact they are plastic and about as brittle as a eggshell.so i dont know what to do to for when i go to assemble everything again. i am thinking maybe some electrical tape. second i finally go my engine out of the truck with a little persuasion from a hammer and a 2x4 and when i pulled the oil pan there was about a hand full of little black plastic chunks sitting int he bottom of my oil pan. I have no idea what it is but if any of u out there do please let me know. thanx for your time and input
Re: rebuild of a 86 4runner 22re motor [Re: veach] #763801 11/08/06 09:51 PM
4Crawler Offline
Plastic is the timing chain guides, or what is left of them. On the connectors, were you releasing the metal spring clips prior to pulling them?
Re: rebuild of a 86 4runner 22re motor [Re: 4Crawler] #763802 11/08/06 09:55 PM
V
veach Offline OP
yes i am releasing the metal clips but they are just breaking as i pull them apart and as for the timing chain guides they are completely intack i pulled the timing cover today and they where still there
Re: rebuild of a 86 4runner 22re motor [Re: veach] #763803 11/08/06 10:26 PM
willzrunna96 Offline
the previous owner probaly is to blame
Re: rebuild of a 86 4runner 22re motor [Re: willzrunna96] #763804 11/08/06 11:07 PM
Staceman Offline
X2
Those pieces float around and get stuck at the oil sump, blocking oil delivery throughout the engine. Probably why you are doing a re-build. A touch of gasket sealer on you connections, away from the copper electrical should keep them connected.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6066 MB (Peak: 0.6712 MB) Data Comp: Off Server Time: 2026-07-16 08:52:16 UTC
