Ring gear ratio #764074 11/09/06 07:46 PM
Brown81CJ5 Offline OP
Does anyone know what the stock ring gear ratio for an '81 CJ5 is? AMC 20 in the rear, and Dana 30 in the front.
Thanks
Brandon
Gun it and run it!
1981 CJ5,258,T-176,D300,AMC 20,Dana 30,Trxus M/T 31x10.50, Rancho 5000's, GroundPounderFab front bumper, polyethylene gas tank, aluminum dash, AutoMeter gauges
Re: Ring gear ratio [Re: Brown81CJ5] #764075 11/09/06 08:49 PM
BigJim Offline
It is easy to find YOUR OWN ratio. Make a mark on the driveshaft and on a tire...Jack up the tire and turn it ONE TURN.. How many turns or parts of turns the driveshaft goes is the ratio!
Wranglers mostly came with 4:11 for a 4 cyl and 3:07 for a 6 cyl.
Re: Ring gear ratio [Re: BigJim] #764076 11/10/06 09:16 AM
derangedcj Offline
Most of the d20 ive found have either 3.31 or 3.73 in em. Theres lots of ways to check though. Pull the cover and count the teeth on the pumpkin and divide by the other set or turn the tires and see how many times the drive shaft rotates. Those work well for getting it quick. Or if yours still has the tag on the axle. <img src="/forums/images/graemlins/kewl.gif" alt="" />
83 CJ-7 3 in suspension. All problems currently fixed. Just Everyone Elses Parts. JEEP
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5915 MB (Peak: 0.6445 MB) Data Comp: Off Server Time: 2026-10-21 17:45:38 UTC
