Page 1 of 3 1 2 3
Vibration #764299 11/10/06 06:34 PM
P
parshal Offline OP
I've got an '83 pickup that I've replaced the in three months ago. I noticed two days ago a strong vibration in the seat when going over 65 mph. If I press in the clutch the vibration goes away. If I release the clutch whether in gear or neutral the vibration returns but goes away under 65 mph. My fix is to not go over 65 mph but I'd like to know what I could have done wrong with the clutch install. It works flawlessly. All I can figure is something on the pressure plate.
Thoughts?
Re: Vibration [Re: parshal] #764300 11/10/06 07:02 PM
U
uglytruck Offline
when you installed the clutch did you use the alignment tool?
if the clutch disk is not alligned properly that would cause a vibration.
88 4runner sr5 v6
needs a lift!
-formerly 86yodaputruck
Re: Vibration [Re: uglytruck] #764301 11/10/06 07:06 PM
P
parshal Offline OP
Yes, I did. I should say that the vibration just started and that's 3 months after the clutch install. I'm going to look at the u-joints first.
Re: Vibration [Re: parshal] #764302 11/10/06 07:14 PM
U
uglytruck Offline
if your gonna check that route.... after checking u-joints, check the big nut at the front of the rear pinion. they have a tendency to work themself loose
88 4runner sr5 v6
needs a lift!
Re: Vibration [Re: uglytruck] #764303 11/10/06 07:18 PM
P
parshal Offline OP
Do you mean under the slip yoke that can only be seen if I remove the rear drive shaft?
Re: Vibration [Re: parshal] #764304 11/10/06 08:24 PM
U
uglytruck Offline
yup, thats the one... came loose once on my 86 and it vibrated so bad i thought the rear axle was gonna fall off
88 4runner sr5 v6
needs a lift!
Re: Vibration [Re: uglytruck] #764305 11/11/06 01:13 AM
OOP'S Offline
You also will not get the tranny to seat all the way in.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Vibration [Re: parshal] #764306 11/11/06 02:32 AM
VanillaTHUNDA Offline
Have you checked the throwout bearing?
Re: Vibration [Re: VanillaTHUNDA] #764307 11/11/06 04:53 AM
OOP'S Offline
Check both of the nuts, the one on the pinion and the one on the T-case.
David Fritzsche
Roseville, CA
Re: Vibration [Re: OOP'S] #764308 11/11/06 07:19 PM
P
parshal Offline OP
Throwout bearing was replaced with the clutch. I'm looking for everything before I go pulling the tranny again.
I tightened the rear pinion bolt but it wouldn't move. I'll try the front, too.
I removed the driveshaft and there is slop in both the rear end and transmission but I can see any movement in the ujoints. The flange on the rear end will move 1/4" or so. I jacked up the rear end and turned the flange moving the wheels. It feels slightly rough but nothing I wouldn't expect from a 23 year old vehicle.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6349 MB (Peak: 0.7415 MB) Data Comp: Off Server Time: 2026-06-17 06:21:47 UTC
