Re: Impellers, relief valve, and flow channels? #764600 11/12/06 09:48 PM
wr250 Offline
ford recommends priming the oil pump before starting the new (or remaned) motor. if you dont do this the warranty on the crate/ford reman is void.ford has issued TSB's on this issue. packing the pump will let it prime quickly, without much hassle.
85 runner -dual cases, headlight harness, 34" TSL's
86 toy buggy getting sas'ed with a 14 bolt rear - 8.5" 10 bolt front (this will go away when i find a 60)
packing didn't work [Re: wr250] #764601 11/13/06 03:03 AM
Packed the pump, the oil made it up a lttle further up the line but very slowly. The pan is next, then the timing chain cover. I have posts all aver this board regarding this issue.
Re: packing didn't work #764602 11/13/06 12:56 PM
Stevie Offline
I've only rebuilt 3, never heard about it, and guess I've been lucky each time with no problems (not noticed anyway).
'80 4X4 Longbed
Re: packing didn't work #764603 11/13/06 02:14 PM
wr250 Offline
timing cover grooved? pull the oil pump and look.
pickup clogged or loose ?
Re: packing didn't work [Re: wr250] #764604 11/13/06 03:55 PM
dcdlexmass Offline
I used regular cam-lube upon my reinstall .... Always keep a small can around for small jobs like this.
-Dana
next steps [Re: dcdlexmass] #764605 11/13/06 07:40 PM
Packing the pump didn't work. I may have left the gasket off the pickup tube. I will be checking that out today.
I don't recall if the timing cover waz grooved.
here's a question (and I may dedicate a thread to this): How many oil journal plugs are there on a 22re block? Where are they? I am thinking that if any are left out it would have to be behind the timing chain cove or else I would have oil leaking since I do have pressure just very low.
Tonight I will be pulling the pan and checking the pickup and removing the timing chain cover to check the journals that may exist there. If that doesn't work what could be my next step?
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6141 MB (Peak: 0.6988 MB) Data Comp: Off Server Time: 2026-11-04 15:49:02 UTC
