IFS front driveshaft alignment #764680 11/12/06 01:51 AM
btn Offline OP
The two rear mounts that hold the rigid IFS axle to the frame have holes that are quite a bit bigger than the bolts. Is that to allow room to shift the angle of the axle to align the u-joints properly? Ever since I switched out my front end diff and bolted things back in, I have had a much harsher vibration with the front shaft turning than before.
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: IFS front driveshaft alignment [Re: btn] #764681 11/12/06 02:18 AM
4Crawler Offline
You would want to set the angle on the u-joint to be at 90 degrees to the driveshaft top-bottom and side-side:
http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#Double-Cardan-Measurements
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5890 MB (Peak: 0.6368 MB) Data Comp: Off Server Time: 2026-06-07 05:02:35 UTC
