auto wont go into gear
#765096
11/13/06 10:21 PM
my automatic wont go into gear wen i push the pedal down my brake lights dont light up. wat could it be?
Re: auto wont go into gear
[Re: pascosportage]
#765097
11/13/06 10:26 PM
Do the brakes work when you press on the pedal? I believe there is a slot by the auto shifter that you can insert a key into and then you should be able to move the shifter lever. I have never worked on an auto trans but it sounds like maybe a linkage between the brake pedal and the trans may be jammed. Just a guess....I'm sure someone on the forum can help you. Good luck! Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: Everet]
#765098
11/14/06 03:06 AM
i think its the stoplight switch. correct me if i am wrong guys. the stoplight switch activates a solenoid that lets you pull the shifter out of park.
[Re: pascosportage]
#765099
11/14/06 04:44 AM
thanks to everyone who replied. but i took it into the dealer cause ther wer a few other problems i dont really have much time to spend on electrical problems right now.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5985 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-10-26 22:34:08 UTCValid HTML 5 and Valid CSS
