auto wont go into gear #765096 11/13/06 10:21 PM
P
pascosportage Offline OP
my automatic wont go into gear wen i push the pedal down my brake lights dont light up. wat could it be?
Re: auto wont go into gear [Re: pascosportage] #765097 11/13/06 10:26 PM
Everet Offline
Do the brakes work when you press on the pedal? I believe there is a slot by the auto shifter that you can insert a key into and then you should be able to move the shifter lever. I have never worked on an auto trans but it sounds like maybe a linkage between the brake pedal and the trans may be jammed. Just a guess....I'm sure someone on the forum can help you.
Good luck!
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: auto wont go into gear [Re: Everet] #765098 11/14/06 03:06 AM
sportagebandit Offline
i think its the stoplight switch. correct me if i am wrong guys. the stoplight switch activates a solenoid that lets you pull the shifter out of park.
96 SPORTAGE 4 DOOR:1 3/8 body lift:eibach springs & spacers:15x8 rockcrawlers & 31x11.50 super swampers:warn hubs:winch bumper http://www.cardomain.com/ride/2115301
Re: auto wont go into gear [Re: pascosportage] #765099 11/14/06 04:44 AM
P
thanks to everyone who replied.
but i took it into the dealer cause ther wer a few other problems i dont really have much time to spend on electrical problems right now.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6005 MB (Peak: 0.6560 MB) Data Comp: Off Server Time: 2026-10-24 13:09:59 UTC
