rebuilding my 2.3 carb #765514 11/15/06 06:55 AM
im sure this may seem stupid but i have a problem with my carb only one side is working what is the best way to fix this problem.
Re: rebuilding my 2.3 carb #765515 11/15/06 01:12 PM
Smorticvs Offline
Buy a new carburetor. Unless you've rebuilt carburetors before and are good at it, justt pony up the $400.00.
Re: rebuilding my 2.3 carb [Re: Smorticvs] #765516 11/15/06 03:36 PM
SuperSwamper Offline
Hmmm, maybe that is the problem with my carb...
we had it rebuilt once, not sure if the guy even touched it or not, it got worse than before we took it to get rebuilt...
Now I have a question is the 2.3L WEBER CARBURETOR from Independent4x any good, or is it poor quality?? kinda expensive
Matt
PICTURES OF MY 1986 ISUZU TROOPER PROJECThttp://www.cardomain.com/ride/2524435/1
Re: rebuilding my 2.3 carb [Re: SuperSwamper] #765517 11/15/06 03:45 PM
Richard Saylor Offline
From what I've heard, Weber is one of the better quality ones and well worth the money. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: rebuilding my 2.3 carb [Re: Smorticvs] #765518 11/16/06 02:55 PM
it looks like the best way is to buy a new carb no problem. BTW do they make a carb to tbi conversion for my 86 trooper?
Re: rebuilding my 2.3 carb #765519 11/16/06 03:50 PM
mlclark Offline
Isuzu Moderator
No.
Michael
Re: rebuilding my 2.3 carb [Re: mlclark] #765520 11/21/06 06:53 PM
desertbenny Offline
The weber carb is a great upgrade. Along with a bigger exhaust pipe, it'll really wake up the 2.3. I'm sure the valve job I had to do helped but it's like a new truck.. <img src="/forums/images/graemlins/kewl.gif" alt="" />
86' Trooper, 2.3, 31" wild countrys, pro comp shocks.
Re: rebuilding my 2.3 carb [Re: desertbenny] #765521 11/23/06 05:48 PM
i liked the weber carb alot but would i still be able to pass a smog check my trooper is the only car a have for the time being. Im looking into getting a new car and turning my trooper into my project car.
Re: rebuilding my 2.3 carb #765522 11/24/06 01:36 AM
Trooper-san Offline
The Weber would be a great upgrade. I put one on a '73 VW bus with a 1700cc engine. I replaced the two single barrel carbs with one two barrel progressive. The difference was amazing. The engine ran so much better, and much stronger.
The only problem was that the state of California, in it's great wisdom, would not pass the bus on smog. The Weber was not original equipment. So, every senond year I pulled the Weber off and slapped the two Solex carbs back on, and coaxed it through the smog test. As soon as it passed the Weber went back on. The bus, btw, is no longer in California. <img src="/forums/images/graemlins/smile.gif" alt="" />
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
Re: rebuilding my 2.3 carb #765523 12/03/06 03:48 PM
MartinR Offline
I rebuilt the Hitachi carburetor on my 2.3 a while back. The following was the best link I found at the time on re-building it.
http://dimequarterly.tierranet.com/articles/tech_carb_tuning_guide.html
The rebuild wasn't quick, but I did get through it. Definitely have alternate transportation if you go this route (I think that is a good idea any time you work on your own cars - if possible).
I know this is a bit late, but did you check your choke or linkage? Why do you think only one side is working?
PHP: 7.4.33 Page Time: 0.065s Queries: 15 (0.005s) Memory: 0.6309 MB (Peak: 0.7331 MB) Data Comp: Off Server Time: 2026-10-21 16:21:04 UTC
