Ignition timing help on Gen1 cali style #765573 11/15/06 07:07 PM
sdjeremyv Offline OP
Ok so I looked through the fsm and my crappy little haynes manuel. I just cant seem to get a clear procedure on setting my timing. As you know the cali version has two vacuum advance chambers attached to the distributer. Do I disconnect one of them? Do I disconnect none of them. What should I set the timing itself at?
Please help!! Been wrestling with this for some time now.
Side question. How do I display a pic with my profile.
Thank you,
Jeremy
Re: Ignition timing help on Gen1 cali style [Re: sdjeremyv] #765574 11/16/06 02:21 AM
I have never been able to get a good answer to this, so I just set the timing with the lines plugged. Can't help with the pic, sorry....
Re: Ignition timing help on Gen1 cali style [Re: fasteddy] #765575 11/16/06 03:09 AM
powerRam50 Offline
my wifes d-50 is a cali.i always unpluged both and set timeing to 7 btdc.
Re: Ignition timing help on Gen1 cali style [Re: powerRam50] #765576 11/16/06 07:07 AM
first, thanks for the help.
one question though. do I disconnect and plug the vacuum lines like I would normally?
Re: Ignition timing help on Gen1 cali style [Re: sdjeremyv] #765577 11/16/06 02:12 PM
powerRam50 Offline
yes
Re: Ignition timing help on Gen1 cali style [Re: powerRam50] #765578 11/16/06 06:18 PM
Ohterwise it will idle like crap and you won't be able to set the timing right. Idle speed is important. I use two 16d nails...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6098 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-05-30 01:14:55 UTC
