22re Stalling #765600 11/16/06 01:28 AM
casper3t Offline OP
My engine with and auto tranny stalls when i put it into reverse or drive. if it doesn't stalls it idles really rough. but if i step on the gas or drive it, it stops. any idea what my problem is?
Thomas
94 Toyota Pickup 22R-E
EB's Street RV Head with 268* Cam
Re: 22re Stalling [Re: casper3t] #765601 11/16/06 03:42 AM
Jeffstoyo Offline
Check the idle speed. Maybe it is set too low.
Jeff
It's all good!
83 Shortbed stepside lots of mods
82 Shortbed fully restored
85 Shortbed daily driver
88 4-runner-Wife's daily driver
Re: 22re Stalling [Re: Jeffstoyo] #765602 11/16/06 03:47 AM
E
EzCruiser Offline
I had a mazda that would do that, and sometimes just die for no reason. I took the ignition switch out, cleaned it and it never happened again. Not too sure otherwise, I'm anxious to see the cause! <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 22re Stalling [Re: Jeffstoyo] #765603 11/16/06 04:44 AM
cmrg63 Offline
U might check with a transmission shop and see if your truck has a torque converter look up solenoid. If so then that might be your problem. I see this in the American built cars all the time.
Re: 22re Stalling [Re: EzCruiser] #765604 11/16/06 05:50 AM
dcg9381 Offline
What does it idle at?
If you turn on the AC what does it idle at?
22REturbo.net
1988 4Runner
Re: 22re Stalling [Re: dcg9381] #765605 11/17/06 10:31 PM
casper3t Offline OP
its idling at 750 and timing is right, i didn't caught the idle when my a/c is on. i think there a vacuum leak but i can't find it. it happens when the engine is warmed up too. well if i had the a/c on and start the car, it would start but die right away.
Thomas
Re: 22re Stalling [Re: casper3t] #765606 11/17/06 11:31 PM
dcg9381 Offline
The AC should have a working VSV valve that engages fast idle when the AC gets turned on. It's a fairly common failure point - there is documentation on how to test it in the manual... Not related to your tranny engagment issue though.
I don't know much about the automatics. Does anyone know if the automatic rigs have something similiar to advance idle against the load of being put in gear?
22REturbo.net
1988 4Runner
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6174 MB (Peak: 0.6905 MB) Data Comp: Off Server Time: 2026-06-10 06:14:37 UTC
