IFS Front driveshaft question #765769 11/17/06 01:18 AM
mudking82 Offline OP
My front driveshaft on the new truck doesn't seem to have a block off plate to stop the grease from coming out of the end of the slip joint. What is actually supposed to be there? Is it a welded in piece, or some type of pressed in plug? Any suggestions short of getting a new driveshaft, or at least the front slip joint part? See pic for where it is coming out. I can stick my finger right up inside the driveshaft, there's nothing there to stop the grease. Thanks in advance.
Jeremy
88 Toyota Pickup 22RE, 31x10.5's, Warn M8000, Marlin rear bumper
Re: IFS Front driveshaft question [Re: mudking82] #765770 11/17/06 01:57 AM
4Crawler Offline
Often a steel plug in there with a small hole. Maybe you could find a rubber stopper or a freeze plug of about the right size and shove it in there. Just make sure there is a small vent hole to let air and excess grease out.
Re: IFS Front driveshaft question [Re: 4Crawler] #765771 11/19/06 12:27 AM
Might have to try that.
Jeremy
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5955 MB (Peak: 0.6490 MB) Data Comp: Off Server Time: 2026-11-02 21:50:51 UTC
