Gear lever extension #765776 11/17/06 01:50 AM
Chris_Rob Offline OP
Have just about finished work on my '94 LWB - 3" body lift, 4" suspension lift, 37" wheels, water/air intercooler, dual shock, etc (pictures on Monday - if I can figure out how to post 'em!)
As part of the work I swapped out the auto trans for a manual. Now, those of use who have done body lifts before are probably aware that the more you lift, the more you have to trim from the floor to let the gearstick move properly. Well, I've got a fix for this. Not the cheapest, but boy it works well! I stripped down both the gear stick and the t/fer case lever and got the levers cut between the pivot point and the end which moves the bits in the gearbox, and got an additional 2" welded in. Then I made up (from UHMPE) 2" blocks which bolts on to the top of the gearbox where the lever usually is mounted. Then I mounted the extended levers on to these. The result is that I can still use the original console and lever boots, and have a much shorter shift for the lever! Works & looks cool! <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 LWB 2800, 91 SWB glass-top 2500, 92 SWB soft-top 2500
(You can NEVER have too many Mitsi's!!)
Re: Gear lever extension [Re: Chris_Rob] #765777 11/20/06 01:11 AM
PartyTruck Offline
Congratulations you just invented the short shift kit. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Did 2" do the trick or is it over the top ??
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Gear lever extension [Re: PartyTruck] #765778 11/20/06 11:35 PM
Well, the gear lever is at a good height, but perhaps I could have done with a BIT more throw in the lever!! <img src="/forums/images/graemlins/lol.gif" alt="" /> The gearknob only moves about 5" from 1st to 2nd!! I'm sure I'll get used to it.
In hindsight, the next time I was doing a 3" (75mm)lift, I'd only extend the lever below the pivot point by 25mm and lengthen the lever above by 50mm.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.5961 MB (Peak: 0.6504 MB) Data Comp: Off Server Time: 2026-11-17 11:29:55 UTC
