Alternator Removal Path. 2.6L Raider with Air Conditioning #765893 11/17/06 05:07 PM
philCA Offline OP
The FSM calls first to discharge the AC and then remove the compressor to obtain access to the alternator. Does anyone know of a different path to obtain this access? Possibilities seem to include (1) removing the radiator, (2) removing the tie rod, (3) removing the fender shield. Input and suggestions from those who have done this would be much appreciated as my Raider is presently deadlined and I am scratching on what to do next. Thanks, Phil
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles
1987 Conquest 2.6L 5 spd w/ intercooler 56K miles
2000 4Runner locking RA 34k miles
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: philCA] #765894 11/17/06 05:55 PM
I don't remember having to discharge the a/c. I think I got it loose (disconnect the battery - before removing the 10mm nut on the fat wire) and snaked it out the back and around the a/c. Had to move some wires and vac lines. At worst, you can unbolt the compressor and lay it aside and remove the a/c bracket, but I don't remember having to. Pulling the radiator should also give room.
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: fasteddy] #765895 11/17/06 05:59 PM
dadrab Offline
Definitely don't discharge the AC. If you have to remove the compressor, just do as Eddy recommended - lay it to the side.
Hell, I changed an engine without discharging the AC.
with awesome audio.
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: dadrab] #765896 11/22/06 05:40 AM
Chris_J Offline
What about dropping a skid plate? At least its not the starter <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: Chris_J] #765897 11/22/06 03:59 PM
I looked at Javy's when we were doing his head. It looks like there's plenty of room if you take the compressor loose (4 bolts, 1 wire) and lay it aside. The sway bar is in the way for a bottom drop. You could also take the fan out and go up the front. DON'T bang the radiator.
Given a choice, I'd go compressor removal.
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: fasteddy] #765898 11/23/06 03:15 PM
N
NumLock Offline
drop the skid plate and snake it out the bottom. you will have to move some of the lower vac lines but thats it.
88 Montero, 2'lift, 31X10.5, front locker.
"Because you're mine, I walk the line."
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: philCA] #765899 08/08/10 04:56 PM
madtabula Offline
I didnt have to remove any of that. I dropped the AC belt then loosened the alternator and snaked it through the bottom. It is a very tight fit between the steering rod and front axel but it comes out.
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: madtabula] #765900 08/08/10 05:49 PM
FrankR Offline
Very timely advice! <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: FrankR] #765901 08/09/10 03:46 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning [Re: MontyMcV] #765902 08/09/10 05:02 AM
zarktheshark Offline
when i did mine, I dropped the skid plate and went out the front. I had to remove a line from the radiator, but that was it. my lower fan shroud is already off and i have a 2in BL, so not sure if that made it easier or not. I think it is going to be a little pain no matter which way you go, so just go to it <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7635 MB) Data Comp: Off Server Time: 2026-06-09 18:19:24 UTC
