Alternator Removal Path. 2.6L Raider with Air Conditioning
#765893
11/17/06 05:07 PM
The FSM calls first to discharge the AC and then remove the compressor to obtain access to the alternator. Does anyone know of a different path to obtain this access? Possibilities seem to include (1) removing the radiator, (2) removing the tie rod, (3) removing the fender shield. Input and suggestions from those who have done this would be much appreciated as my Raider is presently deadlined and I am scratching on what to do next. Thanks, Phil
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles 1987 Conquest 2.6L 5 spd w/ intercooler 56K miles 2000 4Runner locking RA 34k miles
Re: Alternator Removal Path. 2.6L Raider with Air Conditioning
[Re: philCA]
#765894
11/17/06 05:55 PM
I don't remember having to discharge the a/c. I think I got it loose (disconnect the battery - before removing the 10mm nut on the fat wire) and snaked it out the back and around the a/c. Had to move some wires and vac lines. At worst, you can unbolt the compressor and lay it aside and remove the a/c bracket, but I don't remember having to. Pulling the radiator should also give room.
[Re: fasteddy]
#765895
11/17/06 05:59 PM
Definitely don't discharge the AC. If you have to remove the compressor, just do as Eddy recommended - lay it to the side.
Hell, I changed an engine without discharging the AC.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio.
[Re: dadrab]
#765896
11/22/06 05:40 AM
What about dropping a skid plate? At least its not the starter <img src="/forums/images/graemlins/ignore.gif" alt="" />
[Re: Chris_J]
#765897
11/22/06 03:59 PM
I looked at Javy's when we were doing his head. It looks like there's plenty of room if you take the compressor loose (4 bolts, 1 wire) and lay it aside. The sway bar is in the way for a bottom drop. You could also take the fan out and go up the front. DON'T bang the radiator.
Given a choice, I'd go compressor removal.
[Re: fasteddy]
#765898
11/23/06 03:15 PM
drop the skid plate and snake it out the bottom. you will have to move some of the lower vac lines but thats it.
88 Montero, 2'lift, 31X10.5, front locker. "Because you're mine, I walk the line."
[Re: philCA]
#765899
08/08/10 04:56 PM
I didnt have to remove any of that. I dropped the AC belt then loosened the alternator and snaked it through the bottom. It is a very tight fit between the steering rod and front axel but it comes out.
[Re: madtabula]
#765900
08/08/10 05:49 PM
Very timely advice! <img src="/forums/images/graemlins/wink.gif" alt="" />
Frank <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: FrankR]
#765901
08/09/10 03:46 AM
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: MontyMcV]
#765902
08/09/10 05:02 AM
when i did mine, I dropped the skid plate and went out the front. I had to remove a line from the radiator, but that was it. my lower fan shroud is already off and i have a 2in BL, so not sure if that made it easier or not. I think it is going to be a little pain no matter which way you go, so just go to it <img src="/forums/images/graemlins/kewl.gif" alt="" />
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
