Leaf spring shims #766618 11/20/06 09:41 PM
Thord Offline OP
I got a couple leaf spring shims trying to come out. How do i get em back in and how do I get em to stay in???
Thanks <img src="/forums/images/graemlins/mrt.gif" alt="" />
86 CJ7, 258, MC2100 Carb, 4" Rough Country lift, 34" Swampers, Jeeperman bumper/tire carrier
Re: Leaf spring shims [Re: Thord] #766619 11/20/06 11:32 PM
NCBBA2358 Offline
shims or plastic spacer thingies? If you are referring to the plastic pieces that help cut down on rust from metal on metal between the springs at their ends... well, they should come with a tab that goes in a hole that keeps them generally in position. If they don't, then, ummm, duct tape? or perhaps drill a hole in there and squirt some RTV or something in to hopefully hold them in place....
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: Leaf spring shims [Re: NCBBA2358] #766620 11/20/06 11:43 PM
Thord Offline OP
yeah my bad the plastic spacers. they do have holes in them, but somehow jumped out probably flexing offroad??? thx
Re: Leaf spring shims [Re: Thord] #766621 11/21/06 12:12 AM
BigJim Offline
Short pump... Before the plastic thingies springs squeaked.. even a small pebble on the hiway would produce a squeak.
Re: Leaf spring shims [Re: BigJim] #766622 11/21/06 02:21 AM
NCBBA2358 Offline
BigJim, thanks for the imput. Will try to keep squeeky springs in the box spring.... I had no idea why they really put them in, just made sense that it could and does aid in reducing rust....
As for a quick fix of sorts for his anti-squeeky thingies...
jack up your rig by the frame and do everything you can to put weight on the axle so that the spring isn't so tight at the ends of each leaf. Try to get them to pop back in place with a stick or something.
Whew. Brain fried after realizing I lost 50 pounds over the last year!!! Amazing, finding that I don't need another set of srpings myself!
Re: Leaf spring shims [Re: NCBBA2358] #766623 11/21/06 03:17 AM
BigJim Offline
Good job short pump! Very few ever do that.
PHP: 7.4.33 Page Time: 0.022s Queries: 15 (0.020s) Memory: 0.6076 MB (Peak: 0.6770 MB) Data Comp: Off Server Time: 2026-10-22 07:37:27 UTC
