first gear trouble #766633 11/20/06 11:50 PM
all the other gears work fine, but first, i ws told not to be hard on the shifter because i will riune the nylon bushings in between the gears. so if i back up and need to start off i try and go to first gear and it just won't go in. so i go back to reverse and try agen but still won't work. then i go through all the gears and sometimes it will work. what it rong with it?? and how do i fix it??
Re: first gear trouble #766634 11/21/06 10:51 PM
John Smith Offline
The first gear synchro is probably bad but you won't know a thing until you pull the transmission and inspect it.
John Smith 79 FJ40
87 StdCab w/22R TLCA# 9074
Re: first gear trouble [Re: John Smith] #766635 11/21/06 11:00 PM
dcg9381 Offline
Could be a worn pilot or throw out bearing also.
Once it's in gear with the clutch on the floor, does it tend to creep forward at all?
22REturbo.net
1988 4Runner
Re: first gear trouble [Re: dcg9381] #766636 11/22/06 10:48 PM
nope, when i puts the cluch in she don't move. if i have the cluch in and put it in gear it still don't idle down or nuthing. so i really don't no what it is but i no it isent my thro out bearing. because it was fine when i put the new motor in.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5945 MB (Peak: 0.6535 MB) Data Comp: Off Server Time: 2026-10-24 02:34:51 UTC
