Suspension spacers?? #766760 11/21/06 07:35 AM
dsalvetti Offline OP
Hey:
I just wanted to find out if anyone has tried spacers on top of their OME coils. Would it ruin the ride quality?
I was thinking that next spring I might try 1" spacers just to get a bit more height for slightly larger tires. That would put me close to 2.5"-3" of total lift and I would drop the front diff to straighten out the CV angles. I've never really been a fan of body lifts, but if it's the best way to go for just an inch, I'd consider it.
(See my signature line for current tire size and OME coils.)
Any other thoughts?
Thanks,
~Dave
'98 4Runner SR5, 3.4L, 5-Speed, 4WD >>K&N, ISR, TRD Clutch, 265/75R16 Yokohoma Geolandar AT+II's, OME (880/N91SC, 906/N86C)>> SOLD to pay bills.
Re: Suspension spacers?? [Re: dsalvetti] #766761 11/21/06 09:28 AM
kewlynx Offline
The nice thing about body lifts is that it also gives you some maintenance wiggle room, esp for stuff like the starter and fuel filter--at least on the older rigs. <img src="/forums/images/graemlins/notooth.gif" alt="" />
**ubi apis- ibi salus**
Re: Suspension spacers?? [Re: kewlynx] #766762 11/21/06 09:19 PM
willzrunna96 Offline
yea id go with a body lift it will allow more room for those tires, and it wont change you suspension geometry even more.
Re: Suspension spacers?? [Re: dsalvetti] #766763 11/22/06 06:17 AM
fourwd1 Offline
Spacers won't affect ride quality, they're just spacers.
A body lift will give you a little more room for larger tires w/o affecting ride/handling in any way.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: Suspension spacers?? [Re: dsalvetti] #766764 11/22/06 04:22 PM
Jeff the marmot Offline
You definitely don't need a body lift for only 265/75R16 tires. I've been driving hard on 285/75R16 for 6 years without a body lift, although they rub in some situations. Minor rubbing doesn't hurt anything. Even if you had larger tires, a 1" body lift won't resolve the primary rubbing problems, since the body has to move up a few inches to really get rid of the rubbing problem at the rear of the front wheel wells. Just get a hammer and pound the body seam in a few places, which will avoid rubbing enough to avoid needing to mess with a body lift, even for 285/75R16.
Body lifts can be very good if you are determined to fit huge tires or do a SAS, or other extremes. If you want to do a body lift, you should decide before you add custom bumpers and rock sliders since it will affect how all of those are mounted and whether you need to customize those.
A suspension spacer used in combination with other lift springs in the front will affect the ride quality because it will change the geometry of the IFS. It will seem as though it's stiffer. Exactly how much I don't know, since I haven't tried that. I have a spacer above my rear OME springs, but it doesn't really matter there since it just holds the entire rear axle further from the body/frame.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Suspension spacers?? [Re: Jeff the marmot] #766765 11/22/06 06:36 PM
Adam F Offline
Also depends on the design of the spacers. Some spacers go in between the spring and the top plate, therefore preloading the spring and stiffening the ride. Some go in between the top plate and the strut mount, but like Jeff said, they still change suspension geometry.
97 4R, stock, daily driver
Re: Suspension spacers?? [Re: dsalvetti] #766766 11/23/06 06:29 AM
Oh yeah - wheel width and backspacing affects tire rubbing too. Stock wheels are the least likely to cause rubbing. But if you have aftermarket wheels, it may increase chances for tire rubbing.
Re: Suspension spacers?? [Re: Jeff the marmot] #766767 11/24/06 06:25 AM
Thanks guys! 285's would be the largest I would go, so it looks like I'll be ok with the set-up I have. I currently have the stock running boards, but hope to get some "rock rails" and get rid of all of that plastic trim at the front and back of the running boards... that looks like it'll clear out some space at the rear of the front wheel wells, too.
Thanks again!
~Dave
Re: Suspension spacers?? [Re: dsalvetti] #766768 11/24/06 03:34 PM
Tommytuttle Offline
What do you guys think about adding spaces to an otherwise stock suspension.
I would like just a little more hieght but don't know if I'm ready to go the expense of a whole suspension.
Tom P
2000 4runner 5spd SR5 (pretty much stock) Bridgstone REVO(275/70r16)
Re: Suspension spacers?? [Re: Tommytuttle] #766769 11/24/06 09:07 PM
Adam F Offline
Should work for a little while. You'll probably wear out your stock springs after a year or 2. Mine sagged an inch or so.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6394 MB (Peak: 0.7443 MB) Data Comp: Off Server Time: 2026-06-07 10:16:54 UTC
