engine surging/ high revs #766770 11/21/06 11:03 AM
Crops Offline OP
My 89 V6 (auto) is surging. It's running high revs while in gear (intermittently) and when I switch to neutral they go up past 2000 rpm. I have to apply heavy breaks to keep from rolling in gear.
I can't associate this with hot or cold temps -- sometimes it goes away when the car has been turned off -- sometimes it stays. Sometimes it comes on suddenly and stays, or it never happens at all.
Is it a sensor (I've a vague recollection about an o2 sensor).
I am due for an oil change -- anything I should look at myself or direct my mechanic to look into?
Many thanks
Rob
89 Raider V6
95 SR Montero
Re: engine surging/ high revs [Re: Crops] #766771 11/21/06 01:06 PM
FrankR Offline
Clean the IAC:
web page
Frank
Re: engine surging/ high revs [Re: FrankR] #766772 11/21/06 08:05 PM
stony-man Offline
My '92 did the exact same thing, off and on for 4 years. The dealership was happy to replace all kinds of things...nothing ever cured it until I replaced the ECU. <img src="/forums/images/graemlins/barf.gif" alt="" /> Hope yours is something minor...although I think I've seen the GenI ECUs much cheaper than my GenII unit was.
Re: engine surging/ high revs [Re: FrankR] #766773 11/22/06 09:34 AM
Crops Offline OP
Well I cleaned the IAC... we'll see how it goes w/ tomorrow's drive. Many thanks.
Edit to update:
All seems to be running smooth and buttery! Now I need to get that oil changed.
89 Raider V6
95 SR Montero
Re: engine surging/ high revs [Re: Crops] #766774 12/01/06 06:48 AM
monterotx Offline
check your ect the ecu use it to control the idle.
Engine coolent temperture sensor.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6075 MB (Peak: 0.6723 MB) Data Comp: Off Server Time: 2026-06-07 10:33:48 UTC
