4Runner Exocage #766925 11/21/06 11:43 PM
TheBandit Offline OP
Needed something to take my mind off things, so I started working on an exocage for my 4Runner.
First I bent the two B pillars, but I forgot about the camera until they were already done, so let's start with the two A-pillars (below).
(Below) Here I am fitting one of the A-pillars.
(Below) The cage is 1-3/4x0.120. At the back of each A-pillar, I inserted some 1-1/2x0.095 tubing and plug welded it in three places around the tube. Later I will build the back half of the cage starting from these splices.
(Below) Cleanin' up the plug welds with a pearl pad.
(Below) Lots of welding and fitting.
[img]http://thebandit.xtremefabricator.com/exo/exo12.jpg[/img]
(Below) While I don't encourage it, I used a wet towel while welding to keep spatter off the windshield and body.
[img]http://thebandit.xtremefabricator.com/exo/exo13.jpg[/img]
(Below) My welds aren't spectacular, but they should hold fine.
[img]http://thebandit.xtremefabricator.com/exo/exo14.jpg[/img]
[img]http://thebandit.xtremefabricator.com/exo/exo15.jpg[/img]
[img]http://thebandit.xtremefabricator.com/exo/exo16.jpg[/img]
That's as far as I got this weekend. I should mention that while I welded as much as I could on the two cross braces, the A & B pillars are only tack welded at the bottom. When I am done doing the cross bracing, I'll break those tacks and pull the whole thing off to finish welding all the backsides.
I'll take some daytime pictures later this week. Depending on when my treatment starts, I'll pick up on this project again in two weeks.
*EDIT* Daytime pictures added
[img]http://thebandit.xtremefabricator.com/exo/exo17.jpg[/img]
[img]http://thebandit.xtremefabricator.com/exo/exo18.jpg[/img]
[img]http://thebandit.xtremefabricator.com/exo/exo19.jpg[/img]
[img]http://thebandit.xtremefabricator.com/exo/exo20.jpg[/img]
[color:"darkgreen"]1986 4Runner - 4" IFS - 63" Chevys - 33" ATs - 5.29s - Rear Detroit
Sliders - Kayline - Rebuilt 22RE - On Board Air AND Factory AC
www.xtremefabricator.com[/color]
Re: 4Runner Exocage [Re: TheBandit] #766926 11/21/06 11:43 PM
Re: 4Runner Exocage [Re: TheBandit] #766927 11/21/06 11:44 PM
I got a chance to work on the cage again today, so I pulled it off again. Nevermind the rust that's accumulated over the last week.
Here's a look at some of my copes. I love [color:"DarkOrange"]Bend Tech[/color]. It's simply amazing.
First thing was first; getting rid of all the rust. I used CLR and some Scotch Brite pads. This worked INCREDIBLY well. I soaked the pads in CLR, wiped down the tube, and sprayed it off with a hose. All the rust was gone.
Re: 4Runner Exocage [Re: TheBandit] #766928 11/21/06 11:44 PM
Next up, I started welding.... lots of welding. I am using a 110V MIG cranked up to eleven (Spintal Tap joke). My welding isn't phenominal but I'm getting better!
Here it is with all the cross bracing welded up.
Next I emptied a can of Rustoleum Hammer finish silver on all the upper tubes.
[img]http://thebandit.xtremefabricator.com/exo/exo47.jpg[/img]
When I have time again I will weld this onto the truck and get to work on the upper fender bars and cowl tube. I haven't decided yet how I want to do those, but I've got a few ideas.
Re: 4Runner Exocage [Re: TheBandit] #766929 11/21/06 11:51 PM
eightyeight Offline
sick doode. are you planning on extending the cage over the back of the truck or not?
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: 4Runner Exocage [Re: eightyeight] #766930 11/22/06 12:01 AM
DirtyHarry Offline
Toyota Moderator
Looks really good, particularly the fitment between tubes. I think that your welds look good too, as you know it takes a lot of practice to lay down perfect beads.
Are you going to add another bar from the front bumper to the A pillar at the top of the fender?
Re: 4Runner Exocage [Re: DirtyHarry] #766931 11/22/06 12:27 AM
dcg9381 Offline
How are you cutting your tubes?
What's the weight of the exo?
22REturbo.net
1988 4Runner
Re: 4Runner Exocage [Re: dcg9381] #766932 11/22/06 12:52 AM
E
EzCruiser Offline
That is really nice craftsmanship!! Have you considered taking an old truck, cutting the frame off past the cab and making a custom tubular frame like so: Ultimate Toyota Build-up
Re: 4Runner Exocage [Re: EzCruiser] #766933 11/22/06 02:01 AM
Thanks guys, good questions.
eightyeight, yes I am going to extend it to the back of the 'runner, but not for a while. I have some plans for hacking up the rear of the truck that I need to do first.
DirtyHarry, thanks for the complements. I will indeed be adding tube along the top/side of the fenders to the A pillars and a cowl cross bar.
dcg9381, I am cutting the tubes using Bend Tech software (www.bendtech.com) and an angle grinder with a cutoff wheel. I don't know the weight of the cage right now, but I can lift it by myself without too much trouble (other than it being akwardly large).
EzCruiser, I don't think I am going to go 100% tubing out back. I camp a lot with my truck and I want a fully enclosed cab/cargospace. My plans do include a custom bobb and some unique tubing, but I want to SAS before I start the rear half.
Re: 4Runner Exocage [Re: TheBandit] #766934 11/22/06 02:33 AM
willzrunna96 Offline
that is definetly the nicest exo i have ever seen.. good job man!!
PHP: 7.4.33 Page Time: 4.974s Queries: 16 (4.971s) Memory: 0.6494 MB (Peak: 0.7850 MB) Data Comp: Off Server Time: 2026-10-24 05:26:05 UTC
