88-90 2.6L Automatic #767083 11/23/06 01:28 AM
Jayson1 Offline OP
I have gotten the chance to buy another tropper, im not certain about the year but it has a 2.6L and is automatic. The ride is very clean, but has some kind of motor problem, but what im really wondering is how good the automatic trans in this thing will hold up. I have nothing as far as knowlege on these trans, any one with some input. jayson
87 Tropper II, Supewinch Hubs, First big 4x4 test: pulled a 84 Mercury out of a muddy ditch while in park.
Re: 88-90 2.6L Automatic [Re: Jayson1] #767084 11/23/06 03:52 AM
9
94redrodeo Offline
its an aisin trans it is a good trans much better that the 4l30e that came behind the v6's. This aisin trans was also used in some toyotas i believe
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: 88-90 2.6L Automatic [Re: 94redrodeo] #767085 11/23/06 06:52 AM
thepcguy Offline
I drive my trooper daily (typically 60-100 miles round trip) with a little off-roading thrown in for good measure (nothing too crazy). So far the transmission is holding up great.
- Jim
1989 Isuzu Trooper II
- 2.6L 4ze1 Motor
- BFGoodrich 235/75/15 AT
Re: 88-90 2.6L Automatic [Re: thepcguy] #767086 11/28/06 12:06 AM
Jayson1 Offline OP
This trans should bolt up to a 2.3L correct. The engine in this prodject is in so many pieces I think I may just stick my motor in this thing.
Re: 88-90 2.6L Automatic [Re: Jayson1] #767087 11/28/06 01:50 AM
strawmyers Offline
Isuzu Moderator
Yes. If it fits the 2.6, it should fit the 2.3 as well. If you decide you don't want to use it afterall, I'll give you $200 for the bellhousing, torque convertor, and flex plate. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Sean Strawmyer
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6073 MB (Peak: 0.6715 MB) Data Comp: Off Server Time: 2026-10-24 08:14:44 UTC
