Intercooler on C223T
#767170
11/23/06 10:55 AM
Hi all,
I am thinking of putting a small top mount intercooler into my 86 trooper, has anyone done this before? I dont know weather is is worth of the hassle?
Re: Intercooler on C223T
[Re: Viking_t]
#767171
11/23/06 03:05 PM
Are you talking about changing out the stock turbo with the Intercooler turbo? Brian
Brian Rodgers Internet traffic relayed through DIY solar powered WiFi tower. www.outfitnm.com1989 Isuzu Pup gasser 2-86 Isuzu Trooper turbo diesels (1 good 1 bad) Many gallons of biodiesel since 2005
[Re: OutfitBoss]
#767172
11/23/06 08:24 PM
Hi Brian,
I am thinking about adding an interooler to the oringinal setup but I dont know It will make any diff in performance. I want to see if anyone has done this before and their opinion on it.
Cheers, Trong
[Re: Viking_t]
#767173
11/24/06 03:47 AM
Check the archives. I remember reading about the differance between the two here somewhere. Also Acy76 has a blog where he installed the later engine with the intercooler Brian
[Re: Viking_t]
#767174
11/24/06 07:10 AM
Do it.
Any turbo will benefit from an intercooler. But the higher boost you're running, the more you will gain.
[Re: Dougal]
#767175
11/24/06 07:43 AM
Corky Bell's _Maximum Boost_ is an excellent primer on turbocharging. Required reading if you're thinking about modifying your existing system.
If I recall correctly, his advice is to raise the boost to compensate for the pressure drop caused by the intercooler. This would also require an accompanying increase in fuel delivery to take advantage of the added boost pressure. So, the intercooler will allow you to operate with more boost safely, but you will need to re-tune the engine to take advantage of it.
[Re: acy76]
#767176
11/24/06 09:51 AM
Of course even without raising the boost, your engine will be getting more air molecules because the air is now cooler and denser.
If you so desire you can do the more air/more fuel/more air/more fuel leapfrog until you start blowing too much smoke or too many engines.
I'd advise a pyrometer before you up the fueling much at all.
[Re: Dougal]
#767177
11/24/06 10:49 AM
Thanks all for your input and advices. I guess to increase turbo boost I just need to shorten the linkage that connects to the waste-gate? What sort of pressure should I increase it to? I think it comes to 6-8psi for standard setup? I will install the gauge before I make any change to this.
Also, How do I increase fuel to the system on this engine? I though this can not be done on diesel engine? Is it better to run the pipes as short as possible?
Cheers Trong
[Re: Viking_t]
#767178
11/26/06 12:57 AM
You won't need to increase the boost unless you're chasing the performance. In that case you'll be wanting more fuel and boost.
Once you get your pyro gauge installed it'll make a lot more sense. Make sure the temp probe is installed before the turbo, after the turbo isn't as relevant.
More air (from higher boost) = cooler exhaust temps Better intercooler = cooler exhaust temps More fuel = hotter exhaust temps.
[Re: Dougal]
#767179
11/26/06 08:17 AM
OK, I found a small intercooler and an aftermarket bonnet scoop. I need to modify the intake pipe (side way instead of pointing backward to the turbo), then make the bracket for the intercooler...Hopefully I can get it in place by next week. The next thing would be turbo boost + increase fuel (still dont know how to do this yet) javascript:void(0)
Cheers, Trong
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6397 MB (Peak: 0.7598 MB) Data Comp: Off Server Time: 2026-06-07 01:54:58 UTCValid HTML 5 and Valid CSS
