REALLY rough idle
#767193
11/23/06 05:37 PM
i have an 87 4runner 22re. this used to be a freak occurance but i seem to be noticing it more and more these last few weeks. sometimes when i start my car (dosent matter if its cold or warm out) my engine idle drops down to about 500rpms. and my shifter shakes like a mofo. after driving for a min it seems to work out the kink, but has anyone else had this problem?
Re: REALLY rough idle
[Re: ldrdl]
#767194
11/23/06 05:51 PM
My 87 4runner used to idle at 900 now it goes from 1200 down to 600 and back again when im in neutral and warmed up.
[Re: tufsurf]
#767195
11/24/06 07:59 PM
Not sure about this, but it could be the vacuum advance on the distributor. My truck's havin the same problem
1984 Toyota Pickup 22R, carbureted Aussie lockers front n rear 4.88 gears 35's Full exo Marlin crawler
[Re: zachtheterrible]
#767196
11/24/06 08:05 PM
J Roll Me Over
Wow... 3 different problems in one thread...
To the OP: Mine has done this too, off and on for the past 8 years. Unknown cause, and unknown cure. No ill effects in the long term.
To the 1st responder: Turn your idle back down to 750. Problem solved.
To the second responder: There is no vacuum advance on a 22RE... Only the 22R had that (and the early analog-injection Celica 22RE, but that is a different animal altogether).
[Re: DRTDEVL]
#767197
11/25/06 04:49 PM
Turns out that there is a de-celleration pot below the throttle pully. there is a small screw with a lock nut on it. mine was loose and not engaging. a quick adjustment there and my problem solved.
[Re: tufsurf]
#767198
11/25/06 06:25 PM
Turns out that there is a de-celleration pot below the throttle pully. there is a small screw with a lock nut on it. mine was loose and not engaging. a quick adjustment there and my problem solved. dashpot was loose, eh? Last Chance next weekend. You better go. I am <img src="/forums/images/graemlins/cyclops.gif" alt="" />
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6097 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-11-18 08:53:44 UTCValid HTML 5 and Valid CSS
