REALLY rough idle #767193 11/23/06 05:37 PM
L
ldrdl Offline OP
i have an 87 4runner 22re. this used to be a freak occurance but i seem to be noticing it more and more these last few weeks. sometimes when i start my car (dosent matter if its cold or warm out) my engine idle drops down to about 500rpms. and my shifter shakes like a mofo. after driving for a min it seems to work out the kink, but has anyone else had this problem?
Re: REALLY rough idle [Re: ldrdl] #767194 11/23/06 05:51 PM
tufsurf Offline
My 87 4runner used to idle at 900 now it goes from 1200 down to 600 and back again when im in neutral and warmed up.
Re: REALLY rough idle [Re: tufsurf] #767195 11/24/06 07:59 PM
Z
zachtheterrible Offline
Not sure about this, but it could be the vacuum advance on the distributor. My truck's havin the same problem
1984 Toyota Pickup
22R, carbureted
Aussie lockers front n rear
4.88 gears
35's
Full exo
Marlin crawler
Re: REALLY rough idle [Re: zachtheterrible] #767196 11/24/06 08:05 PM
DRTDEVL Offline
Wow... 3 different problems in one thread...
To the OP: Mine has done this too, off and on for the past 8 years. Unknown cause, and unknown cure. No ill effects in the long term.
To the 1st responder: Turn your idle back down to 750. Problem solved.
To the second responder: There is no vacuum advance on a 22RE... Only the 22R had that (and the early analog-injection Celica 22RE, but that is a different animal altogether).
Re: REALLY rough idle [Re: DRTDEVL] #767197 11/25/06 04:49 PM
tufsurf Offline
Turns out that there is a de-celleration pot below the throttle pully. there is a small screw with a lock nut on it. mine was loose and not engaging. a quick adjustment there and my problem solved.
Re: REALLY rough idle [Re: tufsurf] #767198 11/25/06 06:25 PM
toyrunner Offline
dashpot was loose, eh?
Last Chance next weekend. You better go. I am <img src="/forums/images/graemlins/cyclops.gif" alt="" />
1985 SR5 4Runner
eLocked with Carter Lock
4.7:1 single case
Davez Offroad twin stick
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6119 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-06-07 03:21:22 UTC
