Idler/pretensioner pulley #767259 11/23/06 10:56 PM
Eljeef Offline OP
Does anybody know where I can get two new pulleys for my 89? I have tried everywhere local for me and nothing. The dealership (Dodge)can still get them for $76 apiece. These are the pulleys that guide and put tension on the belt that goes around the alternator. Thanks <img src="/forums/images/graemlins/notooth.gif" alt="" />
'89 Dodge Raider/swb/ 3.0L Auto trans/ Bone stock.
Re: Idler/pretensioner pulley [Re: Eljeef] #767260 11/23/06 11:11 PM
FrankR Offline
I'm trying to find them also.... the local dealer tells me that the pulleys are not available. The $75 quote sounds like it includes both pulleys and the mounting bracket assembly.
Sparkem (I think) found a similar pulley at NAPA and made it fit with the use of a washer as a spacer.... nothing wrong with that. Actually, any idler pulley of similar diameter that has a bearing designed for use as an automotive idler should work if it's aligned properly and of sufficient width.... there's nothing special about the OE design.
Frank
Re: Idler/pretensioner pulley [Re: FrankR] #767261 11/24/06 01:03 AM
sasnydley Offline
That is just the pulleys. I replaced mine about 2 years ago. Got them from a dodge dealer- cost over a 100 total then. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Idler/pretensioner pulley [Re: sasnydley] #767262 11/24/06 02:20 AM
sparkem Offline
I got 2 from a Dodge Dealer a couple years back for $50 each. I went to Advance auto and my friend who worked there started pulling pulleys off of the shelf until we found one very close to the Mitsu one. All it needed was a washer to fit. It had sealed bearings too, I have no idea what car it was for or what brand or part number, but it worked. I do remember it was only like $15-20.
Re: Idler/pretensioner pulley [Re: FrankR] #767263 11/24/06 03:54 AM
Eljeef Offline OP
I'll try one of the mitsu dealers on Saturday and if that doesn't work out I'll match it as close as possible. I found one that is real close for $50 apiece. <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: Idler/pretensioner pulley [Re: Eljeef] #767264 11/25/06 05:24 AM
Grasscat Offline
Is this what you are looking for, Tensioner, Alternator drive belt?
http://www.mitsubishiparts.net/cart/?pn=md102451&submit.x=2&submit.y=0
They call it a Conditional Inter. You need two.
The part number is from my parts catalog. (MD102451)
Michael j
TreadLightly! Trainer
Re: Idler/pretensioner pulley [Re: Grasscat] #767265 11/27/06 10:43 AM
Steve Nichols Offline
The Mitsu part No is (I thought) MD308882, least thats the part no on the box when I bought one a couple years back.
I found out that these are originally made by Koyo their part no is PU159026RR1HY. I even contacted Koyo in USA a while back (posted on here) but the guys @ Koyo never came thro'.
I've had problems with belt squeal recently, gone thro' a few belts this year, so I've just emailed HERE 14.56 euros each see if they will supply to the UK
Must be cheaper than the ú50+tax over here (thats about $100+tax for you guys)
SteveN <img src="/forums/images/graemlins/wink.gif" alt="" />
Shogun (Pajero/Montero) 3.0L V6 12valve LWB Auto 1993
142k miles.
Dual Bouncy Seats
Totally stock
c/w Diff lock
now sold
Re: Idler/pretensioner pulley [Re: Grasscat] #767266 11/27/06 12:48 PM
FrankR Offline
The "Conditional" reference in the description means that it's a new part #, superceding an older number..... or so I'm told by a Mitsu parts counterman.
Frank
Re: Idler/pretensioner pulley [Re: FrankR] #767267 11/29/06 03:43 PM
A
Aldee Offline
i have replaced my pulleys a couple of months ago. it cost me around US$40.00 each. Im from manila, philippines. if you want i can shipped them to you. wire transfer via western union. i dont know how much shipping would be as of the moment.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6316 MB (Peak: 0.7357 MB) Data Comp: Off Server Time: 2026-11-04 15:49:35 UTC
